The Cluster Thread
  • dsobering47
    • Oct 2007
    • 697
    #61
    Where are you finding used E46 M3 clusters and DMEs for under $300 for both?
      • 34839
      #62
      ebay
      $119 shipped for the cluster
      you can get a DME without an EWS module for $150-200. you don't need the EWS module for the cluster to work, if that's all you wanted to use it for. MSS54 without a matched EWS module is basically useless without a $1200 re-flash, so they go cheap.
      the only other snag is you likely need the E46 LCM to run the cluster indicators, or modify it to run the LED's manually (turn signals, etc). I haven't decided which way to do that yet.
      keep in mind an E30 M3 cluster is at *least* $300.. and it may need SI board repairs, a new coding plug, odo gears, etc.
        • 34839
        #63
        now with an ECU connected (but not the oil temp sensor yet).. :)
        • dsobering47
          • Oct 2007
          • 697
          #64
          That is badass.
          Now I'm second-guessing my search for an E30 M3 cluster...
          • MaxBell
            • 1391
            #65
            Question: I have a 325e and I've swap in an M50B25TU.
            I have a 325i 7k cluster that I plugged in.
            It all plugs in fine, but the 325i cluster has an extra big plug on the back. I think it's green?
            Will this work fine?
            REMEMBER: Be safe and have fun is Rule Number 1.
            The Epic Unbuild of Clint Eastwood
            • alexw
              • 1140
              #66
              Nando
              Are you saying it would be possible to use the e46 cluster for a regular M50 or S50-S52 swap?
              Or just on a S54?
              Sorry for the swap-noob question.
              alexw
              (2) E30 tourings - sold, E30 M3 - sold, 89 325ix sedan, 91 318is slicktop
              Wisconsin Members!- Join WiBimmers.com, Wisconsin's BMW community.
                • 34839
                #67
                Yes, but indirectly. You need an e46 ecu to drive the tach, coolant and oil temp gauges. Or build a CAN controller and figure out bmw's CAN messages... They give you the hardware adresses, and it adheres to the SAE standard, but the rest is unknown.
