Coolant temp guage question
  • Mistawall
    • Dec 2013
    • 319
    on obd2 is the retreaded e30coolat temp gauge the only option for getting a temp read on you instrument cluster?
    my build thread http://www.r3vlimited.com/board/showthread.php?t=309778
  • Link
    • May 2012
    • 834
    I know that is how i did it. I replaced the throttle body heater line with that sensor and deleted the throttle body heater.
    View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724
    • mpowerful
      • Jul 2013
      • 1273
      I did same. I bought a new sensor, turned it down on a grinding wherl, retapped it, and put it in where the throttle body heater went. Check my thread (s51.5 budget build thread) for pics and details.
      • 2mAn
        SeƱior Mod
        • 20985
        or you can just buy one from Markert Motorworks (328ijunkie)
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • Mistawall
          • Dec 2013
          • 319
          i already did that i had him send one back with my DME when he flashed it. but i was just curious. like how does the e36 get the temp from the DME isn't there an after market temp gauge you could wire in some how?
          • 328ijunkie
            • May 2007
            • 3961
            The e36 cluster sender is integrated with the obd2 ecu sensor thus the 4 pin sensor,
            Sadly it's the wrong resistance range which is why you have to use the e30 sensor still
            Check Us out on Facebook
            Full Product Line Tuning
            • sweet3
              • Oct 2012
              • 752
              Its not the only option...BUT, I think its the only option if you want to use your original cluster gauge.
              PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
              • tytypetersen
                • Mar 2012
                • 347
                Make sure to use a 12 mm crush washer after rethreading it as well. The original 14mm crush washer will cause it to leak, I found that out yesterday haha.
                • M3PO
                  • May 2012
                  • 537
                  Get a VDO gauge and sensor. I have that for mine. Best peace of mind to have a real gauge.
