Rotating the motor for clearance, bad idea?
  • 02stu
    • Jan 2005
    • 872
    I talked to some one today that said he used an e30 m3 mount on one side of his m50 to rotate it enough to accept the stock brake booster, he also had to shave the fins off of the intake manifold. Is this a bad idea? I know m50s are made to operate at a certain angle but would a couple of degrees make any difference? most roads are off camber anyways.
  • DanGillan
    • Mar 2004
    • 4061
    would it work?...
    maybe, but why change something BMW designed to run a certain way? removing the old booster, modifying the new and reinstalling all took about 45 minutes and cost $62.12, i just did it last night, i really dont see the point of fucking with something like that when its so easy/cheap to do it correctly.
    Dan
    • 02stu
      • Jan 2005
      • 872
      Well BMW also designed e30s to use e30 brake boosters so it goes ether way I guess. You got your 320 booster used right? Does it look alright, most of them seem to be pretty beat up.
      • DanGillan
        • Mar 2004
        • 4061
        mine came perfect. i bought it from a salvage yard, they take returns so they wont send you a shit one or they have to deal with the return.
        Dan
        • kylebes1
          • May 2004
          • 2804
          If you push the front of the engine to the right that far enough to clear the e30 booster that would alter the center line too much; this will cause some lateral pressure on the Driveshaft and transmission output.
          The e21 brakebooster can be had new for like $80... There is no advantage to using the e30 booster. If you go to the 2002 booster you will even gain some volume.
          • FredK
            • 14761
            Yo kyle, where is this magical place where you can get the booster for $80 new?
            • kylebes1
              • May 2004
              • 2804
              Over the rainbow...
              woops, $50 more. Advanceautoparts $128
              I think I can get them cheap now that I can order at cost. I will check when I get home.
              • japspecvr6
                • Apr 2005
                • 602
                im about to do a m52 swap..........but now all i need is a booster............but the guy that is doing my swap said i dont need a booster i could use a stock e30 one...........and can the 2002 booster can be fitted to do the job......what mods do i have to do with it.....
                M52 |S52 Cams|E36 Rack Swap|GC Coilover Kit |. . . . . . . . . More To Come
                • rede30
                  • 4697
                  I belive that the 2002 booster needs the same mod as the 320 booster and that is just shorten the rod.
                  • Beej '86 325es
                    • 2639
                    2002 booster has a different end than the E30 or 320i booster, and the E30 one needs to be welded to it...
                    http://www.akgmotorsport.com/usm50swap.html
                    -Brandon
                    '86 325es S50
                    '12 VW GTI Autobahn DSG
                    '03 540i M-Sport (sold)
                    '08 Jeep SRT-8 (sold)
                    For sale:
                    S50 TMS chip for Schricks
                    • joshh
                      • Aug 2004
                      • 6195
                      I thought about this as well but once I was pointed to the oil pickup, my mind changed pretty quickly.
                      "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
                      ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
