Should I boost an M30 or M50?
  • makeshift
    • Feb 2013
    • 131
    My m20 blew in the last 300 miles of a 2000 mile road trip a couple weeks ago. I've been weighing the pros and cons of different engine swaps since. I know I want another BMW inline 6 motor for simplicity and so I have space for a turbo.
    The question is, which engine should I get? I think Im leaning towards an m30.
    I love the sound of mid range torque in the 3.5L, and I was thinking that a turbo would make up for the lack power in the higher rpms.
    Also, the more modern DOHC 24v m50 scares me a little bit, it sounds like more to potentially go wrong when I add forced induction.
    Are these assumptions accurate?
    TIA
    Edit: By the way, I want to build a reliable DD anywhere in the range of 200-300 hp and 10-15 psi
  • frankie591
    • Feb 2012
    • 545
    you can boost that much on a stock, un-rebuilt m30 with stock head gasket all day. so yeah, do that.
    • sayed ali
      • 762
      M30 turbo = WIN and you can easily reach 300hp on low boost
      M20B28 Turbo
      My Build Thread
      http://www.r3vlimited.com/board/showthread.php?t=255839
      • SkorcherX
        • Jun 2011
        • 267
        How do you plan to fuel this M30 at 15psi? Can you blow through the AFM that much boost? How do you tune this?
        I am going to go out on a limb and assume your going to need MegaSquirt of some sort of fuel management to do all this.
        Can the M30 DME be chip tuned or used in tandem with the onstrich software? Please enlighten me.
        • makeshift
          • Feb 2013
          • 131
          Sweet, I would probably still get a thicker head gasket and studs to be safe.
          I'm not sure. What's AFM? I haven't looked into tuning yet.
          Yea, I'm definitely gonna get bigger injectors.
          I have no idea.
          • SkorcherX
            • Jun 2011
            • 267
            Air Fuel Meter. Which I'm pretty sure stock M30s use...
            M50s stepped it up to a MAF (Mass Air Flow) sensor.
            Then if you went with something like MegaSquirt you would use a MAP (Mass Air Pressure) sensor.
            This shits is turbo 101.
            • makeshift
              • Feb 2013
              • 131
              Wow, that clears a lot up. I'm 19, this is my first time doing an engine swap and a trubo. Do you have any good references I can read up on? I am in the process of making money so I can buy a few books and a writeup.. I get paid next week
              • Ether-D
                • Sep 2011
                • 2838
                AFM = Air flow meter
                MAP = Manifold absolute pressure
                "Engine Management: Advanced Tuning" by Greg Banish
                http://www.amazon.com/Engine-Managem...=engine+tuning
                Originally posted by Andy.B
                I was born on 3/25…
                • Ether-D
                  • Sep 2011
                  • 2838
                  Yours would be the first "trubo" e30. Btdubs.
                  I was born on 3/25…
                  • MikeDE
                    • 1873
                    May I recommend, being that this is your first serious mechanical endeavor, that you get the m30/driveline/etc in, running & driving, THEN add turbo a bit later.
                    Don't bite off more than you can chew......
                    Sent from my HTC using Tapatalk
                    -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
                    • rhE-30
                      • 498
                      Solid advice.
                      • george graves
                        • 20003
                        Originally posted by rhE-30
                        Solid advice.
                        The advice above, is sound.
                        Originally posted by Matt-B
