S52 coils with S50 valve cover/harness?
  • Lino
    • Nov 2004
    • 30
    I'm using the s52 valve cover, and the s50 colis don't quite line up to bolt down. What are you guys running, s52 or s50 valve cover? I would like to keep s52 v. cover because it has a better gasket IMO. Also , what mod. is needed to run the s50 wiring harness on s52 v. cover? Any pic. out there for a referance?
    Thanks, Lino
    Lino
    '91 Cabrio
    Factory Hard top
    17x7.5 Kinesis K20
  • C ///M
    • 1040
    Notch/cut out the 'raised lips' in the valve cover to run the wires. You'll also have to make corresponding cutouts on the top of the OBDII engine cover.
    Sorry I'm not the best at describing, but if you run the wiring and coils, you'll see what i mean. Someone else might chime in with better detail.
    EDIT: wait, what do you mean the coils don't line up? That' doesn't make any sense. I'm running the S52 coils that came with my motor, but I thought they were the same. Hopefully somebody will add something.
    332iS R.I.P.
    • Lino
      • Nov 2004
      • 30
      so I can run the s52 coils with the s50/obdI wiring? When i said they don't line up, i'm refering the the holes on the coils to the two bolt holes that bolt it down.
      i see watch you are saying about notching the v.cover for the wires
      Thanks, Lino
      Lino
      '91 Cabrio
      Factory Hard top
      17x7.5 Kinesis K20
      • Jason89i
        • Sep 2004
        • 875
        Originally posted by Lino
        I'm using the s52 valve cover, and the s50 colis don't quite line up to bolt down. What are you guys running, s52 or s50 valve cover? Thanks, Lino
        correct. the s50 / s52 coils have a different design. im using the s52 coils and s52 valve cover (notched as earlier described) with the obd1 electronics. obd1 coil plug fits the s52 coils without any problems.
        cheers, jason
        • Lino
          • Nov 2004
          • 30
          thanks for clearing that up guys
          Lino
          '91 Cabrio
          Factory Hard top
          17x7.5 Kinesis K20
