they will not allow the heater core to get hot water above 3k rpm.....but will not cause an overheat situation.
the stock thermostat is the 88deg one. i like the 80deg, keeps the car cooler, car runs a little richer. however, emissions will probabily be an issue.
if only one hose is getting warm.... then its air bubles, stuck or bad thermostat, or clogged radiator, or poor performing waterpump (broken plastic impellers.)
cheers, jason
cheers, jason
