My m50 is pinging. Running out of ideas.
  • pmat
    • Nov 2012
    • 174
    #106
    Originally posted by Ryann
    Why would faulty VANOS cause this?
    When the VANOS piston seal is worn, the intake cam cannot advance for more cam overlap. This has the effect that internal-EGR (exhaust gas recirculation) is reduced. With less recirculated exhaust in the intake stroke, you will have more air and fuel in the cylinder, but the absence of exhaust gas will increase the combustion rate. Since the spark timing occurs based on the assumed exhaust/air/fuel in the cylinder, the combustion will now be too fast and cause pinging. The pinging is detected by the knock sensor, which in turn retards the ignition with loss of power as a result.
    318is, m50tu g240 s3.46
    • Wishno87
      • 6025
      #107
      Originally posted by Wishno87
      So this is where my fuel pressure is at and it did not move as I revved it up.
      So I replaced my fpr a few weeks ago. Of course that did nothing. I did notice that my fpr said it was supposed to run at 3.5 bar though. If my car is running at 3.1 bar and the engine calls for 3.5 bar could that be the problem?
      • Wishno87
        • 6025
        #108
        Anyone?
        • ak-
          • 12422
          #109
          Makes sense to me..
          My m20 floats at a constant 3bar, so I don't see why your 24v shouldn't be at 3.5
          1991 325iS turbo
          • 328ijunkie
            • May 2007
            • 3961
            #110
            its 3.5 bar with no vacuum on it.
            Check Us out on Facebook
            Full Product Line Tuning
            • Wishno87
              • 6025
              #111
              So am I having a problem with fuel pressure or no? Because I have tried just about everything and nothing seems to have an effect. The e34 is completly stock and a 100k car but does the exact same thing. It's really driving me crazy.
              • Wishno87
                • 6025
                #112
                Just installed a brand new oem maf. Still nothing.
                • surebimmer
                  • Jan 2004
                  • 978
                  #113
                  Your gauge is showing 3.2 bar so i would say your fine on fuel pressure. You can also do a volume test and see if the pump is flowing enough fuel.
                  What brand of fuel are you using? My car would ping like crazy with shell gas and run better with every other brand. Try a different brand and see what happens.
                  • surebimmer
                    • Jan 2004
                    • 978
                    #114
                    and the thread is dead?
                    • Wishno87
                      • 6025
                      #115
                      No I'm still working on it I'm just about out of ideas. I have replaced everything that can affect A/F ratio and nothing makes any diffrence. I usually get gas at chevron but I will try shell for a while.
                      I have two more things I will try before I take it to a shop to pay some goons to tell me "I don't know what's wrong".
                      Compression test and possible replace the main external fuel pump or maybe throw in some other injectors.
                      • amcink
                        • 788
                        #116
                        Did you get any codes
                        • Wishno87
                          • 6025
                          #117
                          Man if I could get one code....just one code....... ANY CODE! That would make this soo much easier lol. But no the OBD is entire oblivious to what is happening.
                          • Habla
                            • May 2004
                            • 1470
                            #118
                            My OBD is also oblivious to my m50tu's 3500 rpm cut. I'm thinking that the fuel pump is dying.
                            Try driving around with the pressure gauge visible, to see what happens under load?
                            -Peter
                            318is slicktop | F15 35dM | F250 SD
                            • Wishno87
                              • 6025
                              #119
                              Just did a comp test and the #s are
                              179
                              181
                              168
                              180
                              181
                              170
                              • ak-
                                • 12422
                                #120
                                Get that wideband working
                                1991 325iS turbo
