Have noted that there are two different types of Knock Sensors for the M and S engine series. The M50 and S50 uses a pair of separate two wire single sensors [ at ~$90 ea. ], while the M52 and S52 is a Siamesed pair of sensors with a single four wire connector [ at ~$90 for the assembly, or half the cost for the same ‘knock sensing coverage’ ].
The S/M50 setup with separate sensors, two wire connectors ea. looks thus:
What do folks who’re swapping an S52, with the dual Siamesed sensors w/ single four wire connector do to adapt to OBDI specs using an OBDI harness having two separate connectors for the separate sensors?
IF the sensors are compatible then it seems all one needs to do is splice / connect the appropriate wires from the respective pigtail(s) to the harness connector(s).
IOW can I use a Dual Sensor setup designed for the S/M52 with the four wire connector [ for one price ] with my S50 engine and splice it into my M50 OBDI harness having (2) two wire connectors. The ECU is a Red Label w/ appropriate Turner chip.
This source http://ddurrelltech.com/bmw/e30_to_m...rsionlist.html implies they are NOT compatible and it can’t be done in that it recommends the following [ snipped from complete swap parts listing ]:That confusing nuff… ‘;) What say Ya’ll? Can it be done… or Not…
TIA…
14 Ping Sensor 2 12141738667 $90.58
Also shown in several pics here as aftermarket from Advance Auto - Single Sensor - Two Wire
The S/M52 setup with dual sensors, four wire combined connector looks thus:Also shown in several pics here as aftermarket from Advance Auto - Single Sensor - Two Wire
16 Ping Sensor 1 12141703276 $90.58
Also shown in several pics here as aftermarket from Advance Auto - Dual Sensors - Four Wire
Question is, can one use either setup for the 50 or the 52 so long as the wiring is properly connected by splicing or splitting as required. That is, are the sensors the ‘same’, only the wiring pigtail and harness being different. BMW is noted for their propensity to revise wiring harnesses especially during the time frame of these engines, i.e. the mid 90’s, ex. best I can tell they had three or four different ‘Front Harnesses’ during a three or four year period.Also shown in several pics here as aftermarket from Advance Auto - Dual Sensors - Four Wire
§ M52/S52 conversions: To go full ODBI (if desired), all the ODBI sensors will be needed, as well as [ snip ]. Need both knock sensors and other miscellaneous things
§ Parts list to convert from ODBII to ODBI
o ‘92-‘95 M50 harness
o Knock sensors (2)
o Knock sensors (2)
TIA…
