HELP! car wont start after being parked for 15 minutes
  • 2mAn
    Señior Mod
    • 20979
    I am clueless whats going on. I literally havent had any problems with the swap since Ive been driving it everyday for the last month. Even earlier today, zero problems, nothing funny. Got off work at 5, drove home. Car sat for maybe 15 minutes after I got home and now it wont start. Its not turning over or anything, so I dont believe its engine related. Possibly the ignition switch? I checked the fuses and they were all good, also checked the grounds and battery cables and everything looked fine.
    Where should I start?
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
  • 2mAn
    Señior Mod
    • 20979
    I think theres something wrong with the car wiring or power getting IN the car. Tried to turn the running lights on to see if the lights on the cluster would turn on and nothing...
    This is my one and only car, so Im trying to get it fixed tonight!!!!!!!!!!!!!!
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    • ak-
      • 12422
      Ground to the pan?
      1991 325iS turbo
      • dewme5
        • Mar 2014
        • 165
        What voltage is the battery at? Sounds like your alternator is not charging, and you ran out of battery power.
        Sent from my HTC6435LVW using Tapatalk
        • 2mAn
          Señior Mod
          • 20979
          Battery showed 12+V, I think its something with the fuseable link. My car was a 318 M10 car that got the battery moved to the back and the battery junction box was never installed so I need to see whats going on
          edit: car is fixed now. I knew it was something stupid. CHECK YOUR GROUNDS!!! It was the ground in the trunk for the battery, not an OEM setup so I cleaned it up and everything is now back to normal.
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
