Early E30 not have C101?
  • Jackhdmn
    • Mar 2014
    • 61
    Hey r3v, I just bought almost everything to do a M50 swap into my 1985 (84 build date) 325e and was wondering what i have to do to wire in my new engine. I cant seem to find a C101 connector and ive read that the really early cars don't have one, is this true and how can I make this work?
  • 328ijunkie
    • May 2007
    • 3961
    They still have it, it's just square and on the other side of the fusebox
    Check Us out on Facebook
    Full Product Line Tuning
    • Jackhdmn
      • Mar 2014
      • 61
      Thanks! I just found it. I also read that extra wires have to be ran. What are they for?
      • 2mAn
        SeƱior Mod
        • 20919
        search c104
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • Poeman446
          • Jun 2013
          • 227
          the extra wires are for the tach, econometer gauge, and something else. I dont remember off hand. its the c103/104 connector under the glovebox.
          • M3PO
            • May 2012
            • 537
            I ran extra wires for:
            -Tach
            I traced the C104 wires back to the cluster and tapped into the tach wire (black) there, ran a wire to appropriate pin of the E36 harness
            -Econoguage
            Same as the tach but it's the yellow/white wire
            -CEL
            The DME uses a switched ground to illuminate the CEL. I mounted a little LED in the dash, provided it switched 12V power (from the stereo) to one pole, and ran a ground wire from the correct pin on the E36 harness to the other pole.
            -VSS
            I had to solder a wire to one of the three pins on the green connector on the back of the cluster and then ran that to the correct pin on the E36 harness.
            -Oil Level Sensor
            The oil level sensor has three wires: Static and dynamic levels and a ground. I grounded the brown wire to the E36 harness and ran two wires through the E36 harness, through the connector, to the correct E30 pins.
