No spark no fuel with a twist
  • BMWerke
    • 893
    FIXED, too much air gap on crank sensor
    1990 325is '94 or '95 E36 auto harness
    Sooooooo. I have an M54B30 in my E30 which refuses to run. Disregard the fact its an M54 and think of it as a little ole M50 because I converted it to OBD1. The intake, knock sensors, icv, all vacuum lines, crank and cam sensor are from an M50.
    The harness is from a automatic E36. This is where it gets a little interesting. The harness is from my friends E36 WHICH HAD A RUNNING M54 IN IT although we are not using the same engine our setups are IDENTICAL. He ran this harness with his M54 in two different E36 chassis with no problem.
    Here are the facts: I hear the dme relay click and the icv buzzing. The fuel pump and o2 sensor relays only come on if I ground them out and or jumper the pins. I have 598 ohms at the crank sensor. I have power at each coil pack and injector. I have the injector ground to the vanos, ground from passenger engine arm to chassis and ground to shock tower.
    I have the brown black wire from auto harness to 12v and i have TWO different red label 413 ecu's. I also have an e34 harness but that gave me issues too. Any ideas?
    E30 E36
    1 25
    4 12
    5 23
    6 22
    7 21
    8 24
    9 20
    11 19
    12 8
    13 13
    14 14
    15 15
    18 18
    20 12v for abs
    '90 325is DD, 5 spd swap-H&R springs-Euro Headlight Fully Built OBD1 M54b30. Ox Blood interior, 3.46 LSD with Z3M Diff Cover. Custom shifter, every bushing replaced.
    '86 325e- Donor car for swap/parts car
    '00 323i- BBS 197s Totalted
    '89 740 turbo Volvo- Donated
  • Matt-B
    The Waffler
    • 3856
    Swap out the main relay, also make sure the front trigger wheel is on its correct pin...
    and report back :)
    • BMWerke
      • 893
      I swapped out the main relay already a couple days ago with an extra one that I had. and i dont have a trigger wheel on the front. Mine is located on the back of the crank and the sensor is bolted to the block, Its an M54 :)
      • Matt-B
        The Waffler
        • 3856
        Ok, is it possible its off a tooth or 2?
        • Wanganstyle
          • 2828
          Do you have:
          Spark
          Fuel
          Test for fuel by spraying starter fluid in the intake manifold; cars will run and idle on starter fluid happily.
          Sent from my SAMSUNG-SGH-I337 using Tapatalk
          • BMWerke
            • 893
            Not really sure what your asking? But if your asking about the timing wheel on the crank then no its not off because the wheel was never removed.
            Originally posted by Wanganstyle
            Do you have:
            Spark
            Fuel
            I tried starting fluid weeks ago, it stumbled for 3 seconds then died. But when i pulled one of the coils and tried to ground it while cranking with a screw driver and I didn't see spark. And I still can't get the fuel pump and o2 heater relay to ground out. The crank sensor is good so im not sure why the ecu doesn't see a signal.
            • 328ijunkie
              • May 2007
              • 3961
              What are you doing for a crank sensor? The factory front pulley doesn't have teeth
              Check Us out on Facebook
              Full Product Line Tuning
              • BMWerke
                • 893
                M44b19 which was used on my friends obd1 m54. its a vr sensor thats the same length as stock with same air gap.
                • mpowerful
                  • Jul 2013
                  • 1273
                  How was the harness spliced? Solder? Crimp? Possible a connection came loose moving it around motors?
                  • BMWerke
                    • 893
                    The x20 was not touched until the harness came into my e30 and i soldered it to my c101
