Blown head gasket or cracked head -- what now?
  • 2ean
    • Dec 2009
    • 177
    I believe a minor coolant leak has turned into a major problem for my S50.
    Everything has gone downhill in the 400 short miles since my last oil change, as there is now a thick milky buildup on the oil cap.
    I'm looking at a blown HG or cracked head...but will a leakdown test tell me which one it is, or is a pulling of the head followed by a proper pressure test required?
    If there's a way to determine it's just the head gasket, I'd be thrilled to replace it. If it's a cracked head, I'm not sure I am interested in fixing this car!
  • IRON-E
    • 16548
    Damn Sean, is there anything I could help with?
    Stop by JMP and see if you can talk to Jerrick about this issue. I'm afraid you are looking at a blown headgsket though.
    @IRON-E30 aka Edwin:D
    • Matt-B
      The Waffler
      • 3856
      I have milky build up on my e36 and e30 with m50, its commi for trapped moisture to gather there. Its generally the highest point In motor.
      • Matt-B
        The Waffler
        • 3856
        I cracked head on m50, was to warped to fix, but generallly its 500-1000 to fix cracks. Id buy a new jead, thats what i did.
        • M-technik-3
          • 18946
          I'd just get a known good head then swap it out. When you did your swap did you replace the head gasket?
          • Wanganstyle
            • 2828
            Leak it down: I had a blow HG between Cyl 4/5; 0 psi in both and pressure came out the exhaust side - leakdown will show air in coolant or oil if head is cracked
            thought it was something worse but turned out not bad at all.
            • 2ean
              • Dec 2009
              • 177
              Thanks for the support E. I'll definitely be in touch when I figure out what route I'm gonna take!
              Considering VAC sells refreshed heads for $900, it sounds like that might be the better option. Unfortunately I won't know if my head is good or bad until I send it out to a shop, which itself will cost $$!
              Didn't touch the motor, as Chris Castro, who performed the swap, personally vouched for it. No real engine issues for the year and a quarter I've had it.
              Will a leak down differentiate between cracked head and head gasket? I think I'll have to get in there and inspect it, no?
              • FLG
                • Sep 2011
                • 3165
                Where are you located? Sound like maybe cali? Take it to shant at bimmer heads and have him take care of you/refresh the head.
                Sent from my SCH-I545 using Tapatalk 2
                -Build http://www.r3vlimited.com/board/showthread.php?t=295277
