High idle and throttle spike
  • shipwr3k
    • May 2014
    • 3
    I just swapped my 1984 318i m10 with a m50b25tu. It starts up and runs however it has an idle of 2200 rpm. If I bearly touch the gas it revs up to 3-4k rpm and sits there even if my foot is off the pedal. I thought it was the tps maybe but it ohms out fine. I know the high idle is generally from a vacuum leak but I am mainly trying to figure out this throttle problem. Using an e34 cable.
  • mpowerful
    • Jul 2013
    • 1273
    Pull boot and make sure throttle flap is closing.
    • justin_l_
      • Jun 2007
      • 1079
      Also check the icv.
      • Nick_S
        • Apr 2011
        • 3658
        Try a new or different tps anyways. Mine did the same thing and ohm'ed within spec. It sounds like your cable could be binding or you have a large vacuum leak around the icv.
        91 318is M50 swapped
        05 Honda Pilot
        24V swap thread
        • shipwr3k
          • May 2014
          • 3
          Throttle plate closes, but not all the way. I'm going to the yard today to grab a new tps. When I unplug the tps the idle drops to 900. Not sure if that means anything. Thankyiu for the replies.
          • Nick_S
            • Apr 2011
            • 3658
            Sounds like your problem. Mine did the same thing.
            05 Honda Pilot
            24V swap thread
