Do I keep the windage tray bolted to the bottom of my s52?
  • dunebuggyjay
    • Nov 2011
    • 257
    Hi Guys,
    I have an e34 oil pan. It has a baffle in the oil pan. I plan on removing this, and went the the $$ VAC oil pan baffle.
    But do I leave the windage tray that was bolted to the underside of my s52 engine?
    Thanks guys.
    Jay
  • nyChris
    • Apr 2012
    • 395
    If you don't have a windage tray attached to the e34 oil pan, you should keep the tray that is attached to the block.
    If you search this has been discussed extensively.
    • dunebuggyjay
      • Nov 2011
      • 257
      Problem is.... the search function does not work on my phone.
      But thanks for answering my question.
      Jay
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        Jay
        Tapatalk has a search function.
        • DesertBMW
          • Aug 2011
          • 1043
          If you are serious about your project then, use real man desktop computer with 20 inch screen at least.
            • 34847
            as unhelpful as ever.
