Looking to do this.  My pump doesn't seem to be able to handle the 6 24lb injectors at WOT high RPM..
					Anyone upgraded a stock e30 m3 fuel pump on a 24v swap?
I had stock E30 325 on my S38B38,,, and it was also more than enoughSveinbjörn Hrafnsson
E30 CABRIO V12 M70B50 ///
ALPINA B10 BITURBO 346 @ 507
E34 550 V12 JML
Finnish wisdom : If you want to Win,, hire a Finn
http://alpina.123.is/pictures/Comment
I guess Mine is just getting weak... It only does it occasionally. I hooked up a gauge and drove it around. Definitely lost a bit of pressure higher in RPM and heavy throttle. I think the FPR is ok, and really think its a weak HPFP in the tank.
did you keep the stock LPFP located under the car when you upgraded to the e36 pump? or does that get bypassed? My car was sitting for at least 4 years before I did the swap.Comment
You have the pumps backwards. In tank is low pressure, below the car is high.
If you "upgrade" the pump, bypass the under car pump and install a high pressure pump in the tank.
Stock pumps should be more than plenty for an S50US.2006 GMC Sierra 2500HD 4WD LBZ/Allison
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpicComment
Cool, thanks for the tip! That's what I was planning to do. I bought a walbro gss342 (flows 255LPH) to put in-tank. I figured this was the easiest/cheapest way to fix the issue. Is there anyway to diagnose which pump is the culprit (or the FPR for that matter)?
My car is a 1990, didn't think it got much later than that.Comment
Stock (working) pump(s) will flow ~36lb injectors fine.
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
A lot
Of
M3s had dual pumps
I must have a 600 hp car
According to my gauge, fuel pressure tapers off just a few pounds at WoT in the high RPM. 43-45psi occasionally tapering to 35-38psi. I ordered a new walbro that flows 255lph, but wanted to make sure a failing fuel pump is the only scenario that could be wrong in the fuel system. The car does have a new fuel filter.Comment
The screen on your in-tank pump could also be somewhat clogged. I would replace that when you replace your pump (if you do the in-tank one) while you're in there.88 325is - S52 powered
Originally posted by King ArthurWe'll not risk another frontal assault, that rabbit's dynamite!Comment
