what kind of oil for your s52?
  • Frenchtoast
    • Apr 2014
    • 12
    Those of you that do your own oil,
    what oil brand/type/weight are you using? how many quarts?
    Thanks
  • justin_l_
    • Jun 2007
    • 1079
    Conventional Valvoline VR1, 6 qts or brad penn
    • mpowerful
      • Jul 2013
      • 1273
      Motul 8100 x-cess 5w-40. 6.5qts(i think or thereabouts).
      • zcenterb
        • Feb 2014
        • 2105
        Not sure if it matters from S50-S52 but I'm using Mobil 1 synthetic european blend in my S50. 0W-40 i believe. 6.9 qts is what the book says.
        CENTERBAR MOTORSPORT - Check out my small Bimmer/Beamer parts and custom projects business!
        Instagram: @centerbarmotorsport
        Facebook: https://www.facebook.com/centerbarmo...?ref=bookmarks
        The Fleet:
        -1984 325ei Lapis
        -1991 325ix Diamond
        - 2005 X5 4.4i Black Sapphire
        -1972 2002tii Fjord - SOLD 7/8/17
        -1991 325i S50 ///Sterling Silver/// - SOLD 9/15/17
        The Bike:
        -1980 R100RS Inca
        • Bimmerman325i
          • 6854
          Rotella 5w-40.
          You will get 12 different answers for every 10 people you ask.
          2017 Chevrolet SS, 6MT
          95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
          98 M3/4/5 (stock)
          • justin_l_
            • Jun 2007
            • 1079
            Your best bet is anything high zinc/phosphate
            • 318isbmw
              • Nov 2005
              • 2843
              Rotella 10w-30 for me.
              • mrcheezle19
                • Apr 2012
                • 1451
                mobil1 15w-40 for me
                Dude this is r3v. 20 bucks gets you a used timing belt or a low mileage head gasket
                • Frenchtoast
                  • Apr 2014
                  • 12
                  Originally posted by Bimmerman325i
                  Rotella 5w-40.
                  You are so right, thanks for all the replies
                  • ajhostetter
                    • Apr 2013
                    • 1218
                    BMW (Castrol) 10w-60 if you want to pay a bunch and get meh oil
                    Amsoil 5w-40 European car formula if you follow the guide on their website
                    Amsoil 15w-50 Race Oil if you track your car and have played around.
                    I'm an Amsoil fan, but really, you'll get a million answers. It also depends on how you use the motor (lot's a time b/n 5-7K rpm) and the temps where you live and if you run your car in the cold. The second weight # is really important for high-stress, high temp environments. You need good viscosity there. If you're never going drive your car when it's 40 degrees out, use a straight weight oil. Or better yet, check out Amsoil and RedLine's websites. They both have some good guides.
                    2014 GTI | 2002 Land Cruiser | 1991 Volvo 745t
                    • sweet3
                      • Oct 2012
                      • 751
                      I use Castrol 5w 30 or 5w 40. For these engines you don't really want to use conventional yet. I would go with a synthetic blend.
                      I used conventional valvoline vr1 in my m20 motor because the cams and rockers needed a nice amount of zinc. I also went with conventional because the oil particles are a bit thicker, so the seals didnt leak.
                      These engines are not as picky.
                      PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
                      • MrSlacker
                        • 2494
                        Rotella T6
                        My Seller/Buyer Feedback
                        Performance Aftermarket Parts & Accessories
                        • gkurey
                          • 882
                          Mobil1 syn 15w50
                          • Wanganstyle
                            • 2828
                            BMW standard synthetic oil.
                            BMW TWS 10-60 is for S54/s62/s65/s85 engines with motorsports double vanos
                            • TimKninja
                              • 2131
                              I use ethier Lubro Moly 5W-40 or Mobil 1 15W-50
                              I used Castrol 0W40 once and it made me feel meh. Didnt burn anything, never burns any oil with over 200k on it, but a bit of lifter tick after an Auto-x(To be expected).
                              Id stick to a Good Synthetic 5W-40 for these engines.
                              1985 325e M50TU(Sold)
                              1991 318is Slicktop (Sold)
                              1990 325is Brilliantrot S50/5 Lug Swapped.
                              1992 525i Manual shitbox Winter Beater
