what kind of oil for your s52?
  • Bimmian89
    • May 2012
    • 170
    Mobile 1 15w-50 full synthetic
    Check out my build thread!! :p
    http://www.r3vlimited.com/board/showthread.php?t=288383
    • butters
      • 1205
      Shell Rotella T6 5w-40
      I'd be curious to hear comments on going from a good -40 to a -50. Seems heavy, but I still get occasional lifter noise with new lifters and totally rebuilt motor. Although I've heard it's best to stay consistent with 1 oil, changing formula/weight can be detrimental.
      • Bimmerman325i
        • 6854
        Depends how you intend to use the car. The engine was designed for 20w-50 conventional oil originally before emissions and fuel consumption targets forced the switch to 5-30. My 95 M3's owner manual specs 20w50, for example.
        I track and dd on the Rotella t6 5w40. I tried using M1 15w-50 a long time ago and the car loved it on track, hated it everywhere else. It really hated it below 45 degrees.
        Unless you primarily hoon in the car, I wouldn't change from the Shell stuff. It's good oil for a mixed purpose car.
        2017 Chevrolet SS, 6MT
        95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
        98 M3/4/5 (stock)
        • M3PO
          • May 2012
          • 537
          My S50 has M1 0W40 European in it right now and it seems to like it. Same thing I use in my S65.
          • rwh11385
            lance_entities
            • 18403
            Quality post, would read again.
            • NotJesus
              • Mar 2015
              • 169
              Liquimoly Leichtlauf 5-40, or something else on the liqui moly line. $9-$11 a quart but it's made in Germany and comes very highly recommended. Check it out on ecs tuning-
              https://www.ecstuning.com/ES2785255/...paign=autoCart
              • MC Hammered
                • Jul 2008
                • 2076
                Rotella 15w40
                My 1989 e30 s52 Touring... this is Betty
                My 1989 325i vert (sold)...this is Nina
                My 1991 M5 (sold)... this is Veronica
                Photo comparison: OEM vs aftermarket windscreen for a convertible
                • NC325iC
                  • Mar 2004
                  • 6565
                  rotella t6 (the t6 is important) 5w-40
                  • berlow94
                    • Jan 2013
                    • 1063
                    Been solely running Liqui-Moly Racetech 10w60 in my built S52 track car. Fantastic results. I would recommend against diesel oil. Give Blackstone Labs a call
                    The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
                    • MC Hammered
                      • Jul 2008
                      • 2076
                      In addition to what the owners manual says here is a BMW TSB that was forwarded to me a while ago from an e36 M3 owner.
                      SUBJECT
                      Engine Oil Level Check
                      MODEL
                      E39 M5 with S62 engine, E52 Z8 with S62 engine, E36 M roadster, M coupe with S52 and S54 engines, E46 M3 with S54 engine
                      SITUATION
                      General Information:
                      The race bred engines incorporated in BMW M vehicles include increased power output and maximum engine speeds compared to conventional BMW engines.
                      Due to their high performance design characteristics all M engines may exhibit slightly higher oil consumption compared to conventional BMW engines.
                      A spirited driving style (especially during the critical engine break in period) will lead to further increased engine oil consumption.
                      BMW recommends checking the oil level and if necessary topping up using the correct viscosity whenever refueling is required to maintain the value of your BMW throughout its service life.
                      Engine Oil Recommendations / Engine Oil Level Checking Procedure
                      8 Cylinder Engine (S62)
                      6 Cylinder Engines (S52, S54)
                      Engine Oil Recommendation:
                      M5 produced up to 3/00:
                      Castrol Formula RS SAE 10W-60 or
                      Castrol TWS Motorsport SAE 10W-60 Synthetic Oil
                      BMW Part Number: 07 51 0 009 420
                      S52:
                      BMW High Performance Mineral Base Oil
                      SAE 15W-40*
                      BMW Part Number: 07 51 0 017 868
                      or
                      M5 produced from 3/00, Z8 all:
                      BMW High Performance Synthetic Oil
                      SAE 5W-30
                      BMW Part Number: 07 51 0 017 866
                      BMW High Performance Synthetic Oil SAE 5W-30
                      S54:
                      Synthetic Oil
                      Note: For logistical reasons Castrol Formula RS SAE 10W-60 Synthetic Oil has been renamed and is now called Castrol TWS Motorsport SAE 10W-60 Synthetic Oil. Since the formulation has remained the same it is sold under the same BMW part number (07 51 0 009 420).
                      Engine Oil Level Check Procedure:
                      S62
                      S52, S54
                      1. the engine must be at operating temperature
                      2. let the engine idle for at least 15 seconds
                      2. turn the engine off
                      3. turn the engine off
                      3. wait at least 1 minute for the oil to drain down into the sump
                      4. wait at least 1 minute for the oil to drain down into the sump
                      4. check the level using the dipstick**
                      5. check the level using the dipstick**
                      Notes:
                      All vehicles must always be parked on a flat surface when checking the engine oil level, it is recommended to always check the level whenever refueling is required.
                      This will ensure that the proper oil level is maintained throughout the life of the vehicle and during the critical engine break-in period (approximately 5000 miles) when the engine may have a tendency to consume slightly more oil.
                      *For reliable engine performance in all temperature ranges mineral based engine oil viscosity must be matched to the temperature range at which the vehicle will be operated. Check the temperature viscosity chart in the Owners Manual or Operating Fluids Manual for further information.
                      ** The space between the two marks on the dipstick corresponds to approximately 1.1 US quarts (1 liter). Do not fill beyond the upper mark on the dipstick. Excess oil will damage the engine.
                      Only if a customer needs to top up oil between oil changes and Castrol Formula RS SAE 10W-60 or Castrol TWS Motorsport SAE 10W-60 Synthetic Oil is not available is it permissible to use synthetic engine oils with a lower viscosity which conform to the API classification SH or higher.
                      Engine oil consumption will increase when Castrol Formula RS 10W-60 Synthetic Oil or Castrol TWS Motorsport SAE 10W-60 Synthetic Oil is diluted (topped up with other low viscosity synthetic engine oils).
                      Other causes for oil consumption may be a spirited driving style during the vehicle break-in period which does not conform to the procedure listed in the owners manual and on the sticker located in the upper left hand corner of the windshield (Example: "Up to 1200 miles / 2000 kilometers no full throttle, Max. engine speed: 5500rpm, Max. speed 106m/h - 170km/h",etc.).
                      As with fuel economy, engine oil consumption is directly influenced by driving style and vehicle operating conditions.
                      The BMW M Engine Oil Information brochure (see attached illustrations) is included in all BMW M vehicles and will give the customer quick reference information regarding engine oil recommendations and checking procedures.
                      Due to the new oil recommendations for the S54 engine the new M Engine Oil Information brochure (print date 6/01, see illustration below) supersedes the earlier version brochure (with out a print date).
                      Additional brochures are available under part number SD92-116 and can be ordered from Product Engineering (a pre-printed order form is attached).
                      WARRANTY INFORMATION
                      Information only.
                      Note: All S54 engines now use Castrol Formula RS SAE 10W-60 or Castrol TWS Motorsport SAE 10W-60 Synthetic Oil.
                      • Sh3rpak!ng
                        • Jan 2014
                        • 2667
                        Originally posted by Wanganstyle
                        BMW standard synthetic oil.
                        BMW TWS 10-60 is for S54/s62/s65/s85 engines with motorsports double vanos
                        This.
                        This also. I have found the same results. Car is much smoother on the rotella t6 5w40. S52 should be using synthetic, not conventional oil.
                        Look for oils with the BMW LL-01 qualification.
                        If you want to use some expensive, but very good stuff, here's liquimoly's product page with all the qualifications per each oil: http://www.liqui-moly.de/liquimoly/m...$file/5439.pdf
                        Here's some more general info regarding BMW engine oil: http://www.opieoils.co.uk/pdfs/BMW-O...s-and-Recs.pdf
                        Shadetree30
