M50tu sudden Powerloss *SOLVED*
This is not true...I've daily driven mine for 3 years with no issues. Still passes smog with flying colors.
OP I would try replacing the ECU with a known working one. Also why aren't you running an O2 sensor? Mine ran terrible with a bad sensor.
1991 LS1 Swapped 318is
Instagram:
https://instagram.com/saltybeast/
LS Build Thread:
https://www.r3vlimited.com/board/for...s-e30-ls1-swapComment
Hey guys so it might be the fuel pump.
Hooking up a pressure gauge, I got about 40psi at idle, when Reving, the pressure drops to 35psi as the revs climb.
Pulling the fuel vacc line to the FPR, the pressure jumps up to 45psi, but as soon as the injectors increase load, the pressure drops to around 40psi.
Doing a 2nd gear pull, the pressure stays around 38-41psi. Way to low. The FPR was replaced with a known good one.
VIDEO
**SOLVED**
Woot Mothafucking WOOT!
OK heres the lowdown for anyone interested....
Fuel pump failed.
Cat decimated.
I think when I hooked up vacuum to the gas-tank, it caused too much load on the pump and partially killed it. When my pump went handicap, that burdened my cheap Magnaflow cat, which decided to commit suicide, and collapse and cause a major clot.
New pump installed, replaced the cat and fished out what we could of the destroyed cat guts in my muffler, she runs strong again! AND PASSED EMISSIONS by 2nd gear with E85 haha. The guy didnt even have to shift into 3rd before the test ended.
Thanks all for you help.Comment
What injectors are you running with e85? Your problems sound similar to mine, I think my fuel pump is on it's way out and might've ruined the cat from running too lean.Comment
