starting issue help please....
  • DanGillan
    • Mar 2004
    • 4061
    bump, any last help would be great, im going to work on it again tonight i think.
    Dan
    • KangamangusDriver
      • Aug 2005
      • 1870
      Get that thing running and driving yet??
      • DanGillan
        • Mar 2004
        • 4061
        havent worked on it actually, im going saturday afternoon to work on it.
        Dan
        • Skafrog
          • 1732
          Did you shave the oil pan? Also, you need to have the constant power, switched power, and the ground to the starter. Check the leads for cracks. Take the starter out and apply 12volts, and see if you can get the starter to spin and move outwards.
          Also, make sure your starter is actually in there right. If you have a big case starter, you need to modify the block slightly.
          NASA MidSouth TT Director / GTS2 #018
          Mods: Coastal PS Fluid, 10w40 Oil
          Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
          • DanGillan
            • Mar 2004
            • 4061
            yep, shaved the oil pan, motor turns over by hand perfectly. yea seems that i do have constant, switched and ground to the starter, it does work on a bench test and it lines up perfect. im working on it saturday, im just gonna take the clutch and starter off and install everything again making sure its perfect, i cant think of anything else to try,
            Dan
            • 1990m3
              • 1180
              try to turn it over with the gearbox off the car so you can see if the starter engages with the flywheel. I can't think of anything that would prevent you from turning it over without the trans bolted up, but I'm probably off on that one
              • DanGillan
                • Mar 2004
                • 4061
                yea... good idea... i wanted to do that, except the starter bolts up to the bellhousing in order to mount. haha oh well. ill figure it out im sure
                Dan
                • Beej '86 325es
                  • 2639
                  How do you know if you have a big case starter?
                  -Brandon
                  '86 325es S50
                  '12 VW GTI Autobahn DSG
                  '03 540i M-Sport (sold)
                  '08 Jeep SRT-8 (sold)
                  For sale:
                  S50 TMS chip for Schricks
                  • 325Projectz
                    • Jan 2005
                    • 1956
                    Duct tape, DUH!
                    91 m3
                    • DanGillan
                      • Mar 2004
                      • 4061
                      sounds mean :evil:
                      Dan
                      • BeirBrennerE30
                        • 2740
                        got it started??? what was the problem???
                        e30sport.net
                        '06 M3 Competition - 6-speed
                        '97 Range Rover Vitesse
                        • DanGillan
                          • Mar 2004
                          • 4061
                          i still dont know. the only thing i changed was i put in one block to bellhousing dowel, the other side didnt fit, so im only rocking that one. other than that i meticulously put everything back together after much measuring and inspecting along the way. and as soon as i went to start it first key turn primed the fuel, second key turn started right up and idle perfectly. so relieved and excited to drive it, should be done mid week.
                          Dan
                          • BDSax
                            Junkyard King
                            • Mar 2006
                            • 3594
                            Edit: Nevermind/
