Differences in Flex Discs for swap
  • rbartongrimley
    • May 2008
    • 286
    So I have an s50 & zf310 in my e30 and I have been using the revshift swap disc and decided I wanted to go OEM.
    Picked up a 99 M3 driveshaft but it didn't come with a guibo. I know people have talked about the fact that the e36 328is manual driveshaft works as well as the m3, but now I ask the question: what is the differences in the flex discs?
    e36 328 manual flex disc: 26117511454 $60
    e36 96+ M3 flex disc: 26112226527 $115
    What could possibly be the difference between the two besides slightly different rubber compound? They are both 96mm/12 and seemingly are the same size otherwise, though I am guessing the m3 one might be a bit thicker.
    Any input on this? What should I go with?
    Do Work www.sbeuroclub.com
  • surebimmer
    • Jan 2004
    • 978
    They only difference that i am aware of is the thinkness. The 527 part number is 35mm thick.
    Check out this post
    • 328ijunkie
      • May 2007
      • 3961
      Different hardnesses. Get the M3 one if you drive like a lunatic. 328 or ~87 eta one if youre cheap.
      Check Us out on Facebook
      Full Product Line Tuning
      • M3PO
        • May 2012
        • 537
        I have the used one (87k miles) that came with my trans (96 328i) in my car with a super eta driveshaft with no issues. I drive the car pretty hard, lots of burnouts and power slides lol
        • diesekte
          • Sep 2013
          • 417
          Eeuroparts has the 96+ M3 flex disc (meyle) for $68
