E36 M50 automatic wiring harness to fit a manual swap
  • amcink
    • 788
    What do I need to do to use an automatic harness onto my 5 speed swap?
  • mpowerful
    • Jul 2013
    • 1273
    Cut all the auto wires out then connect one wire the 12+. Cant remember the exact one but there is plenty info out there.
    • amcink
      • 788
      How many wires approximate to need to cut?
      • mpowerful
        • Jul 2013
        • 1273
        15 or 20 or so
        • mpowerful
          • Jul 2013
          • 1273
          Its easy to cut. Just cut all the ones going to the automatic tranny control unit. Pull em out.
          • M3PO
            • May 2012
            • 537
            You don't have to do anything I don't think. I cut out everything that went to the trans computer plug and also the plug that goes down to the trans. I had I think three left over wires that went from the trans computer to the DME. I didn't connect them to anything.
            • amcink
              • 788
              How about the one the goes to the manual transmission since I'm using a G250 how I know which one it is?
                • 34839
                you can simply remove all the automatic wiring, or leave it as is. there's nothing else to modify.
                use a wiring diagram if you want to modify a harness.
                • M3PO
                  • May 2012
                  • 537
                  The only wire that goes to the manual trans is the reverse light switch. That is part of the E30 body harness not the engine harness.
