Differntial problem concerning my new m50 swap
  • socalife
    • Jun 2014
    • 177
    So I just got the car, and it formally had a 4 cylinder engine on it with a 4.1 open differntial. You know since I just got the car, I've been stepping on the gas and redlining but all of a sudden I hear gear whine in 1st gear and whine throughout the higher rpms. Also, I get a loud click everytime I step on the gas. Do I need to change it?
  • SkiFree
    • Jun 2011
    • 2766
    It's very likely.
    ADAMS Autosport
    • dynoclimb
      • Nov 2011
      • 88
      this can happen...
      or this....
      or both....
      2006 Subaru WRX
      1987 E30 Royalblau Metallic S52 OBDii
      1982 VW Westfalia 1.5d-gone
      • shocwav3
        • Apr 2014
        • 69
        I would say she is smoked.
        • 328ijunkie
          • May 2007
          • 3961
          168mm Diffs dont like abuse or power..
          Check Us out on Facebook
          Full Product Line Tuning
          • socalife
            • Jun 2014
            • 177
            What about the clunking noise from the back when I step on gas
              • 34837
              That would be your small case diff crying for mercy.
              • shocwav3
                • Apr 2014
                • 69
                Driveshaft bolts in the rear are tight? U joint have any slop?
                • THEhomelessONE
                  • Oct 2013
                  • 303
                  Lol your car's bitchin for some LSD
                  RIP 02/25/15
                  http://www.r3vlimited.com/board/show...16#post4356816
                  • sam_
                    • May 2014
                    • 630
                    Those diffs won't take any abuse.
                    1991 325i
                    flickr
                    @sambhaskins
                    • Jib05
                      • Aug 2012
                      • 149
                      Destroyed my small case diff with a 2l m20. Change le diff.
                      .................................................. ...................sigpic
                      .................................................. ............................. ......M50B25 3.1L stroker
                      • SkiFree
                        • Jun 2011
                        • 2766
                        I'll disagree....... 168's are good with mild abuse up to 230-ish. If you're bustin it before then, then you've been neglecting the case and something other than simple "too much power" is/was the root of your trouble.
                        ADAMS Autosport
                        • Wanganstyle
                          • 2828
                          Have you checked your transmission / differential fluids?
                          Perhaps put a piece of cardboard under the car when u park and see if anything is leaking; If you are low on fluid for either it will be whiny
