mpg tach gauge help
  • arthb7
    • May 2012
    • 329
    mpg tach gauge help
    I have 1984 325e that I swapped an m50nv into. My wiring adapter was pre made by catuned. I attached the extra wire on the adapter in the glove box to make my tachometer work but my mpg needle doesn't move. Is there another wire I have to connect somewhere?
  • M3PO
    • May 2012
    • 537
    Yes, in the same plug in the glove box where you connected the black wire to the E36 tach signal wire, there is a yellow/white wire that needs to be connected to the correct E36 wire (it was Pin 24 on my S50). Keep in mind that the econometer will be wrong.
    • arthb7
      • May 2012
      • 329
      Thank you I will try to figure it out!
      • 2mAn
        SeƱior Mod
        • 20989
        perfect, I was just thinking about this today!
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • arthb7
          • May 2012
          • 329
          Thank you again I just tried it and pin 24 works like a charm!
