I'm using a 325ix booster with an e34 M5 master cylinder. Right now I have an iX reservoir that is deforming the rubber throttle body elbow way too much. I haven't been able to find a BMW v8 remote reservoir locally.
I found the brake master cylinder grommets and fittings from a Jaguar v12 XJ-S pictured here:
The master cylinder in the Jag is also a Girling and the fittings are a perfect fit. You could use the reservoir bottle from a Jag but I'm going to either get a single reservoir with three outputs or 3 individual bottles. (2 for the brakes, 1 for the clutch).
A couple cars over to the Jag was a Talon - it also had a remote reservoir. For kicks; I removed the fittings and grommets from the master cylinder from it. The grommets / fittings will do the job the only thing that is keeping them from being a perfect fit is that the fittings are alittle too tall and should probably be cut down height wise to fit. The only bad thing about this is that it would remove the ridge on the nipple - I'll be taking pictures later to demonstrate :-)
