what fuse to run with 255 fuel pump?
  • e-dirtym52
    • Aug 2012
    • 338
    Put in a 255 fuel pump and was driving and blew the 7.5 fuse. I put in a 30 amp but I don't want to draw too much power and screw anything else up. Is 30 amps too much or is it ok?
    Thanks
    If you're not going to do it right, please don't take it out on your car!
  • glnr13
    • 1334
    put the 7.5 back in. Oem bosch is 255lph too so you're not drawing more amperage than before. If you're blowing 7.5's then something else is wrong.
    • matthugie
      • Mar 2004
      • 1810
      Agreed, I kept the 7.5A when I put in my Walbro and it was fine. Check your wires.
      88 325is - S52 powered
      Originally posted by King Arthur
      We'll not risk another frontal assault, that rabbit's dynamite!
      • e-dirtym52
        • Aug 2012
        • 338
        Ok. Thanks. If it makes a difference it blew while coming to a stop at 40 or 45
          • 34834
          if you put in a 30 amp fuse in place of a 7.5a, you're running the risk of a fire. there's a reason that fuses are sized they way they are.
          • GunMetalGrey
            • Dec 2010
            • 1499
            I and a friend both kept randomly blowing the 7.5a fuse after installing a TRE 255lph and Walbro 255
            Using 10A and no longer having issues, though I know its not a long term solution.
            • e-dirtym52
              • Aug 2012
              • 338
              i'll just throw in the 7.5 and if it blows again i'll put a 10 in until i can trace back where it's going bad at
