IAC/ICV Delete...has anyone done it?
  • shocwav3
    • Apr 2014
    • 69
    Curious if this has been done on any M50/M52's.
    I have seen other platforms do it when running standalones, so I was thinking its a plausible option for us if there is a way to get the dme to ignore it.
    I have no "NEED" to do it, but I wouldn't mind cleaning up under the intake a bit and simplifying the setup.
    Can it be done with something like Miller's WAR chip or is a full standalone probably the only way to go?
    TIA
    • 34844
    don't do it. there's no "cool" points to be had. all it will do is make driving the car when cold miserable.
    • shocwav3
      • Apr 2014
      • 69
      Does it operate beyond idle? I can't see it making a difference in drive-ability otherwise.
      Have you ever seen someone try it?
      I'm probably stuck on what I have seen work on other platforms. DSM's get rid of it pretty quickly when going for bigger boost, same with fords. Shit, there are plenty of cars I have worked on that got rid of both IAC and MAF and run MAP with per-configured settings under idle conditions (to include BMW's)
      I should mention that my car is not a daily and adding forced induction is the end result.
      Thanks for the input. Just trying to educate myself from others experience.
      • nyChris
        • Apr 2012
        • 395
        I run an obd1 s52 with an m50 manifold.
        My ICV is currently unplugged because it is faulty, and was causing my idle to surge. It runs perfectly fine once up to temp, and to my surprise it didn't trigger a CEL (I am not certain if the Turner chip omits ICV CEL codes).
        The only problem I have experienced is on cold starts it will idle around 500 rpm. I am assuming come winter if I don't replace the ICV I will have issues with stalling at idle.
        • shocwav3
          • Apr 2014
          • 69
          That's interesting, so its probably safe to say its only controlling idle.
          I figure it would have to be omitted via a tune in order to control idle directly off throttle plate position.
          • DaveSmed
            • Apr 2007
            • 1407
            The ICV will play just fine with forced induction. Just clamp down the hoses going to it if your going nuts with the boost.
            Removing it just makes the car worse.
            -Dave
            2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
            Need some help figuring out the ETM?
            • matthugie
              • Mar 2004
              • 1810
              Idle Control Valve controlling the idle? Madness!
              88 325is - S52 powered
              Originally posted by King Arthur
              We'll not risk another frontal assault, that rabbit's dynamite!
              • shocwav3
                • Apr 2014
                • 69
                The reason I was asking if it controls anything other than idle is everyone's response, that it will make the car run worse.... If its only controlling idle, than the car might idle worse, but run just fine...
                I posed a question wondering if anyone has deleted it, and actually gone through the process of having the dsm ignore it. I've seen it done on other platforms and wondered why. Doesn't seem that anyone has done it on the M50/m52 motors, or doesn't want to talk about it.
                Thanks for everyone's input.
                  • 34844
                  it sucks. that's why nobody talks about it. Guys who only drive it to a race track, sure. there's not really a great reason to do it other than "just because".
                  • jalopi
                    • 2370
                    Ever tried starting a carb'd car with a broken choke when it's cold outside? You live up north, if this car is gonna be driven in sub 60 temps deleting the IAC is a bad idea.
                    • DaveSmed
                      • Apr 2007
                      • 1407
                      If I had to hypothesize why it gets removed on other platforms, i'd look at the type of idle control they run. Theres various methods, some crap, some complicated, some more trouble than they are worth. I would guess the DSM idle control might not play nice with standalone engine management thats popular on that engine, but I am just speculating.
                      Fortunate for us, the BMW one is easy to control and use with standalone management, and its a German part with a wire sticking out of it thats actually fairly reliable making it quite rare indeed.
                      -Dave
                      • justin_l_
                        • Jun 2007
                        • 1079
                        I'm still running it on my DSM in the 500hp range.
                        • shocwav3
                          • Apr 2014
                          • 69
                          That my friend is comforting. I'm going to look up your build thread, I would very much like to see your set up.
                          • shocwav3
                            • Apr 2014
                            • 69
                            I demand a build thread!
                            J/K-Maybe its on here, but I couldn't find it.
                            • GunMetalGrey
                              • Dec 2010
                              • 1499
                              I am running ms3x on my M50 turbo and left the idle valve in, it took me about 10 minutes of fiddling with settings (having almost no idea what I was doing) to get it to function correctly. To tune the idle you simply change the duty cycle of the valve. I don't know why you would want to take it out, but to each his own.
