So I tried to bolt the ix booster into my e30 m3 and it simply won't fit because the bolt holes do not line up - the bolt to bolt distance is different. There's some talk about this issue in this thread:
But, no one states what the solution is. Someone commented that there might be coupler between the booster and the firewall. Can anyone confirm this? Realoem doesn't show it. And, I don't recall seeing this when I pulled the booster from the ix. I recall removing the nuts from underneath the steering column which would mean that the bolts go through the firewall. This won't work for my conversion car unless I start drilling holes. Help!?
