m50 gods, I require your expertise
  • SirMaxximus
    • Oct 2014
    • 180
    Picked up an 325es last week with an m50tub25 in it. the guy who I bought it from installed it and seemed pretty informative but told me it was misfiring cylinder #4 he needed to get rid of it before winter as he has a baby on the way and 2 other project bimmers and not enough room in the garage.. I wanted a project e30/weekend driver and got a great price on it (rust free!!!).
    Heres the thing, it misfires, it idles rough, it hesitates, hiccups and rpms drop really slowly. I spent a good hunk of the weekend diagnosing and the biggest problem is I think it's misfiring on several cylinders intermittently… I agree cylinder #4 seems to be the most often, but pulling any plug on any cylinder shows a drop in rpm… I'm not convinced its only #4
    heres the specs and tests I've performed so far:
    spark test: all cylinders sparking
    spark plugs: replaced with the OEM .032 NGK's
    Coil in line tester: all coils working, if I swap #4coil to a different one, #4 cylinder still seems the most obvious
    Compression Test: all cylinders 180psi +
    Fuel injector noid test: all fuel injectors have steady/smooth signal
    Swapped fuel injector #4: no difference
    no vacuum leaks confirmed, I can hear a light hiss if i hold my ear up to the manifold (actually near #4). I've sprayed starting fluid all over this area with absolutely no proof that theres actually a leak. (another m50 guy told me this hiss maybe normal, can anyone confirm this)….
    if its not the intake manifold gasket I'm down to it being very electrical, like a dead DME or a bad camshaft/crankshaft sensor.. can anyone confirm a legitimate way of testing these? or any other ideas, things I haven't tried?
    below is a picture of my plugs (you'll notice number 4 is the only one without black soot, I'm thinking that supports my gasket idea if its just being leaned out)
    87 325es - M50 Boosted - Link to BUILD THREAD
    07 328xi wagon 6mt - daily
  • SirMaxximus
    • Oct 2014
    • 180
    Only codes shown from my peake reader are as following:
    oxygen sensor - (oxygen bungs have clearly been plugged and has no cats so no downstream o2s either)
    vehicle speed signal not present
    ignition secondary monitor
    remember that I had been tinkering with all these things during diagnosis, it also showed coil and fuel injector codes for each cylinder. I cleared the codes. drove it around a small bit, and the only thing that came back was the o2 code.
    • DesertBMW
      • Aug 2011
      • 1030
      had very similar problem, it turned out to be bad MAF and DME did not show a code for a bad MAF. Also torn intake boot can do this.
      • Dj Buttchug
        • Jun 2010
        • 7672
        No.
        Op,
        its your garbage champion spark plugs. change them out for NGK.
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • SirMaxximus
          • Oct 2014
          • 180
          Originally posted by Dj Buttchug
          No.
          Op,
          already did, no change
          intake boot was very thoroughly checked. I thought MAF but if i unplug it while its running it will die, so it still must be doing something… could it still be bad though?… is there an appropriate way of testing it?
          • Jib05
            • Aug 2012
            • 149
            try a smoke test?
            .................................................. ...................sigpic
            .................................................. ............................. ......M50B25 3.1L stroker
