S52 Swap Coolant Temp Sensor Re-treading
  • ksjdan
    • Jul 2012
    • 330
    Ok Im ready to drop the engine in, but just need to figure out what to do about the Coolant Sensor. I don't wish to pay $50 for a sensor, and I have a re-treading dye set so might as well put it to use. Only question is, what is the exact size? I dont want to take the risk or stripping or damaging the head tread hole.
    Anyone tried this yet with successful results?
    My 1990 325is Build Thread
  • BlackSpeed66
    • Apr 2008
    • 618
    This thread has all the info you need.
    -Geno
    '87 325is (s52'd)
    '95 525iT
    '02 Range Rover 4.6 HSE
    '98 Disco 1
    • tytypetersen
      • Mar 2012
      • 347
      12x1.5. I took my time with a file and shaved it down until the dye caught on.
      • 328ijunkie
        • May 2007
        • 3961
        Rethread with a die or buy one from us or theres some other guy now selling them in the FS board
        Check Us out on Facebook
        Full Product Line Tuning
        • ksjdan
          • Jul 2012
          • 330
          Thanks fellas. I actually saw that post few months ago and asked the OP. He said he wasn't sure exactly which die he used, but 12x1.5 seems to be the one.
          • ksjdan
            • Jul 2012
            • 330
            I have another question, but dont really want to start a new thread.
            So i have a brand new m20 slave cylinder and a e36 m3 slave with 70k miles stock. Used with s52 and zf. Which would you say is better for the swap purpose?
            Sent from my VS980 4G using Tapatalk
            • Northern
              I like cupcakes & sh!tboxes
              • 5247
              I'm under the impression that you can't use the M20 G260 slave with the ZF320, so I'd say use the 70k old ZF slave.
              But now that I think about it, maybe the early eta G260 slaves would work because of the deeper bellhousing, but I have no idea if they really will.
              Originally posted by priapism
              Originally posted by shameson
              • justin_l_
                • Jun 2007
                • 1079
                I usually buy a new slave when doing swaps. They are cheap enough. Get what ever one matches the trans.
