Hey r3v people. First post.
Recently did a m50 swap to my 91 318is.
I am just trouble shooting some problems and need a little help.
Current setup
-91 318is
-Getrag 260 and 325 drive train
-m50 from 1991 m50b25nv
-Akg Harness adapter
Problem 1-
My starter won't engage the fly wheel
Things I've done to trouble shoot
Starter tested at AutoZone- passed
Tested the wiring by laying starter on frame rail with all wiring hooked up and hit the key for a second.
Bendix popped out and gear turned.
In short it's not the wiring or starter.
I did shave the oil pan a bit to let the flywheel sit flush.
Motor turns by hand but the starter will not turn it.
Single mass flywheel from Getrag 260
It almost seems like a space issue.
Anyone else have a problem with the swap where the starter can't reach or goes to far over the flywheel and not turning the motor?
Current setup
-91 318is
Problem 1-
