how to get oil temp gauge to work in OBDi S50 swap in e30 m3.
  • m3j0n
    • Feb 2006
    • 395
    Is it possible? what needs to be done?
  • 328ijunkie
    • May 2007
    • 3961
    Easy, add sender, wire through c101. Profit.
    Check Us out on Facebook
    Full Product Line Tuning
    • berlow94
      • Jan 2013
      • 1063
      Nt possible.
      The m3 doesn't use electricity.
      It functions with radiation. The radiation the M3 sender uses isn't compatible with the electricity the E30 gauge cluster wants.
      The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
      • Bmjpv
        • Mar 2007
        • 561
        Oil temp works
        I installed an e30m3 cluster in my 88'is at time of my s52 swap. Very cool to have the oil gauge temp working.
        • berlow94
          • Jan 2013
          • 1063
          After being a d**k.
          Which pin in the back of the gauge cluster is for oil temp?
          • surebimmer
            • Jan 2004
            • 978
            http://bit.ly/1G21PAp
            Looks like post #3 shows pin 19 on the c101
              • 34847
              I think the S50 already has the sender for oil temp, and it's the same as the E30 M3. you just have to hook it up.
              • 328ijunkie
                • May 2007
                • 3961
                Euro S50 yes. US no. Need to buy E30 M3 oil temp sender and install somewhere on engine. Wire through C101
