No Fuel, and driveshaft problems
  • 02stu
    • Jan 2005
    • 872
    So I tried to start my m50 for the first time and I'm not getting any fuel or any current at the pump. I've checked the relay, fuse and made sure the violet and whatever color is connected. The car did sit for a year with a blown engine so it might not be swap related. Any ideas on what it might be? On a side note I tried to connect my e36 325i driveshaft and found it to be about 3" to short, so ether the 325i shaft will not work or I have an auto driveshaft, does anyone know if the manuel unit is longer? Thanks again
    -Stu
  • FredK
    • 14762
    Yes the manual driveshaft is longer. Is there a part number?
    Are you the guy using the Getrag 240?
    • 02stu
      • Jan 2005
      • 872
      Yep I'm useing a 240, good idea I didn't think about checking the part number I'll do that when I get off of work. Thanks
      -Stu
      • aeryk7
        • Oct 2005
        • 616
        Loosen the driveshaft and seperateit at the splines it should reach if it was from a 325is coupe not 4 door atleast this is my experience.
        253rwhp
        My Vids(OLD)
        http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
        http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
        • aeryk7
          • Oct 2005
          • 616
          Probably your fuel pump pull the thing out. If it sat for a year it is all gummed up you might be able to get the pump to work again by shooting some spray lube into the botom of the motor and try turning the blade carefully with a pocket screw driver. Ask me how i know i went through a brand new one already also fill the tank with new gas.
          253rwhp
          My Vids(OLD)
          • aeryk7
            • Oct 2005
            • 616
            Oh yeah check for power at the pump with a test light . Relays need to be in the right spots make sure your ecu is properly grounded along with make sure your engine ground strap is secured.
            253rwhp
            My Vids(OLD)
            • JJ Byzanz
              • Apr 2006
              • 33
              Mine wasn't working until I connected the Grn/Vio and Grn/Wht from E30 to the Grn/Vio on the E36 harness.
              • japspecvr6
                • Apr 2005
                • 602
                shit i think im going thru the same problem......but minds is like this when i rev in neutral the car doesnt shut off...... but when im driving it just shuts off and this time it wont turn back on............and im not getting anything from the pump........could it be clogged........
                M52 |S52 Cams|E36 Rack Swap|GC Coilover Kit |. . . . . . . . . More To Come
                • 02stu
                  • Jan 2005
                  • 872
                  I'd start with replacing your fuel filter. Then make sure your relay is fine before you replace your pump. I would put money on it being the filter though.
                  • Sean
                    • 5793
                    Yea, my dad jumped to the fuel pump in his E34, ended up being a relay or something? Either way - start with the cheap stuff - relays and whatnot.
                    - Sean Hayes
                    • DEV0 E30
                      • Oct 2004
                      • 8901
                      A local guy who used the 240 (has a late model 318i 5sp) said he shortened his driveshaft 2 inches when he did his M50 swap, he must have taken it somewhere to get it shortened and balanced.
                      And agreed go with the cheap stuff first.
