My boosted S52 started misfiring under boost badly within the past week. Replaced plugs with the same plugs and the same gap and that did not help the issue. I tested all of the coil packs and they were within 1-1.1 Ohms each which should be in spec with a baseline of .3 from my multimeter.
Is there another test for coilpacks besides resistance between the two outer pins?
This issue just started last week and has been getting worse, with the plugs out of the question I'm pretty sure it has to be a coil going but I just don't want to buy 6 to replace it with.
