M52 swap Knocking !!!! HELP
  • e30m20TurbO7
    • 1203
    I have a immediate knock that is coming from the motor, it sounds like its coming from the bottom end, i pulled every coil one by one, and no change,
    i accidentally put on the e34 oil pan baffle "windage tray" when installing the pan, any idea if the baffle could be hitting the crank
    heres a photo
    is this my case ??
  • 328ijunkie
    • May 2007
    • 3961
    I had an experience a few years ago that taught me a lesson about windage trays. The M50 and S52 ones are Massively different because of the obvious stroke differences. I put an M50 one on an S52 car and had the slightest contact between one of the rod cap bolts and the windage tray. Was a horrible noise....
    Check Us out on Facebook
    Full Product Line Tuning
    • craz azn
      • 749
      Maybe yours was damaged? AFAIK, they are all the same part shared between the M5x engines, including the S52. At least, it worked fine for me when I swapped an M50 scraper tray onto an S52.
      Rippin' Proper | Youtube | Vimeo |
      • DesertBMW
        • Aug 2011
        • 1040
        I made the same mistake but was lucky enough to spin the engine by hand while it was still out.
        • Northern
          I like cupcakes & sh!tboxes
          • 5278
          E34 M50 is riveted to the oil pan, Rear sump engines have the one pictured.
          It sounds like OP has the E34 one installed. I feel like this isn't an unheard of issue:
          Originally posted by priapism
          Originally posted by shameson
          • craz azn
            • 749
            http://www.bimmerforums.com/forum/sh...windage-tray-!
            Not all E34 pans have the built in trays... The pan in my E30 does not have this, and uses the regular bolt-onto-block tray (on an M52 FWIW, and no contact). I'd look up the cutoff date for when which pan superseded the other, but I'm too lazy :)
            • mpowerful
              • Jul 2013
              • 1273
              ^ this. There are different baffles. I used an m50nv pan that had a baffle rivveteted in. It didnt hav e crank clearance issue but it woulf not clear the gusseting in the block so i had to trim it.
              • luckysnafu
                • Jun 2008
                • 262
                I ran into the same problem, had to take the engine out and replace the baffle.
                M/S52 Wiring Diagrams
                Z3M S52 to late model 325i wiring diagram
                M52 to 318is wiring diagram
