M52 timing cover Qeustion URGENT
    Can oil mix with coolant if the gasket for the timing cover goes bad, ???
    what else other than a head gasket will cause oil in the coolant
    Possible but extremrly rare/nearly unheard of
    Check Us out on Facebook
    Full Product Line Tuning
      No a bad timing cover wouldn't (or at least shouldn't) mix with coolant. Do you have any pictures?
        It can though. Water pump is sealed against block there as well as oil from timing chains
          I just had some condensation build up under the cap.
