s52 swap AC - R12 or R134 ??? what is required?
  • Tippey764
    • Aug 2014
    • 108
    What lines do you use to have an E36 M52/S52 a/c compressor in an e30?
    • Sh3rpak!ng
      • Jan 2014
      • 2667
      you go custom. Either splice e36 lines to e30 lines or buy the pre made lines from zionsville
      Shadetree30
      • M3PO
        • May 2012
        • 537
        Sounds like you've got it figured out out, you just need to change the seals to ones that are compatible with R134a.
        • Andy Mechnic
          • Jan 2015
          • 117
          If you're in SoCal and speak Spanish or have Mexican friends you can go down to TJ and get your R12 filled hella cheap.
          • Sh3rpak!ng
            • Jan 2014
            • 2667
            Yes, it really isn't/wasn't that difficult. I was just not sure what stuff I can reuse or have to replace... looks like I basically replace it all minus e36 compressor
            lol oh well. I'll wait until it gets hot
            Shadetree30
            • sweet3
              • Oct 2012
              • 752
              This might be a little off topic, but when I am coming to a stop with my AC on, my car stalls. How do you hook up the AC so that the car bumps up the idle?
              I have a line running from the x20 (pin 4 I believe), and it runs to the one wire on the AC.
              PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
              • mpowerful
                • Jul 2013
                • 1273
                Read here for ac idle bump http://www.r3vlimited.com/board/showthread.php?t=249136
                • KI4UJO
                  • Jun 2011
                  • 642
                  If you want 12, just get certified. Its literally an open book test and a $15 fee. At that point, you can buy all the 12 (and 134a sold in large quantities) that you want.
                  However, just use 134 like everyone else has said. I converted mine, and it is extremely cold.
                  IMG_0145 by Jonathan Martin, on Flickr
