M52 rebuild help
  • n8ge
    • Nov 2014
    • 34
    M52 rebuild help
    Hello all...
    I was just wondering what parts I ALL need for my m52 rebuild, I just want to get all the parts at once and just rebuild it all at once. Are there any kits out there reasonably priced or am I going to have to have to piece it together? If so, could someone include a list I would need for every part? And what brand is suggested. I know it's a lot to ask, but I would GREATLY appreciate it. I'm a noob. But thanks for your time, I hope someone helps me lol. :-(
    91' 24v 325i
  • n8ge
    • Nov 2014
    • 34
    Head Gasket Set
    Lower End Gasket Set
    Valve Cover Nut Bushings
    Head Bolts
    Rod Bearings
    Main Bearings
    MaxSil Tefcote Pistons
    Sealed Power Rings
    Timing Chains - Upper and Lower
    Timing Chain Guide Rails - Upper and Lower
    Timing Chain Tensioners - Upper and Lower
    Timing Chain Tensioner Piston
    Oil Pump Chain
    What else?
    91' 24v 325i
    • mitten_e30
      • Feb 2015
      • 4
      I recently rebuilt my m52. Everything above listed I got my parts from pelicanparts.com. Very good prices and fast shipping. I went with arps head studs they are around the same price if i remember right the oem ones are like $16 a peice. Good luck with build.
      • mitten_e30
        • Feb 2015
        • 4
        Forgot to add get rod and main cap bolts! they are tty bolts and cant be re-used.
        • essi1553
          • Apr 2012
          • 440
          Upgrade the Oil pump while your down there. Also a good time to rebuild vanos (depending on engine mileage)
          Exhaust manifold studs and nuts, thermostat housing, hoses below intake manifold, upgraded ARP hardware, but it depends on the extent of the build. There are so many options to consider "while you're in there" becomes very dangerous. Don't forget to put some money aside for clutch.
          • n8ge
            • Nov 2014
            • 34
            Thanks guys! I really appreciate your help! I will do all suggested.
            91' 24v 325i
