CEL troubles
  • ayemattyyy
    • Apr 2008
    • 411
    CEL troubles
    Hi all,
    I have a NVm50 in a 1991 318is, and am not getting a CEL lighting up or stomp test to read out. I have tried a 402 red label and 403 green label to no avail. A CEL is needed in CA to make it smog legal.
    I have checked all the fuses currently installed, the CEL bulb is getting power, tested the continuity between both sides of the c101 connector and the bulb at the cluster, and am getting 12v there.
    Thoughts?
    Wrong wiring? Could there be a break from the c101 to the DME?
    Matt
  • ayemattyyy
    • Apr 2008
    • 411
    Bump
    • 2mAn
      SeƱior Mod
      • 20985
      dumb question but is the wiring done through the C101? On mine, the CEL is on the X20 pin #8, a gray wire... being a late model, you could attach that to the C101 wherever the CEL wiring was.
      Im in Almaden right now! Lets go drive Hicks!!!
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
