Motor Mount problems
  • Sea Aych
    • Apr 2013
    • 766
    I'm mid-M50 swap, and have the green funky-shaped engine mounts from the e28 535i.
    The passenger side sits nice and flush with both the motor mount arm and the subframe, but the diver's side leans outwards so that it's about 4-5mm from being flush with the subframe.
    Has anyone else run into this issue?
    I found a post on e30tech from someone that had the same problem, but he ended up just torquing them down as best he could and calling it a day. Is that my only option?
    Here's his pic. Mine looks exactly the same in terms of how it sits (i have different mounts obviously - he's using AKG i think):
    http://www.flickr.com/photos/2185850...n/photostream/
    1988 Atlantisblau Euro/Japanese 325i Cabrio
    1989 Schwartz 325i - now M50 powered! - now very dead
    1998 Toyota 4Runner Limited - gone
    My 17,000km Big NA National Parks trip!
  • 328ijunkie
    • May 2007
    • 3961
    The E28 mounts install backwards. Stud through dowel hole and dowel through stud hole..
    Check Us out on Facebook
    Full Product Line Tuning
    • Sea Aych
      • Apr 2013
      • 766
      Yup, outside hole, thats already done, and still have little angle for some reason on the driver's side
      • drulle
        • Dec 2008
        • 1906
        Had same exact issue with my S52 swap, I slotted the holes towards the motor in e36 aluminum arms on both sides and it did the trick. (holes that engine mount studs goes through)
        "i love vee tek, its a wonderful sound when you driving right by it"
        If you bought anything from me, please leave a feedback here: http://www.r3vlimited.com/board/show...ghlight=drulle
        • Sea Aych
          • Apr 2013
          • 766
          Great, thanks! No issues with trans alignment after that? Currently mine's sitting a little closer to the passenger side of the tunnel
          • drulle
            • Dec 2008
            • 1906
            No, no alignment issue with tranny. GL
            • cojo
              • Nov 2012
              • 24
              Off to the Side
              Same thing here, I ended up drilling out the arms and now the tranny/shifter sit to the passenger side a bit. I re-bent the shifter a bit more than I had originally.
              I do not have the swap completed so I cannot comment on how it will pan out, the drive shaft and CSB all bolted up ok though.
              Good luck
              • E36M3LX
                • Sep 2012
                • 31
                what i had to do was loosen the bottom bolts on both motor mounts so there was room to angle the motor mount into the motor mount arm. then lowered the motor onto the mounts and tighten the bolts back up. not ideal but zero problems so far. will be switching to condor mounts that are made for this swap soon.
                • Sea Aych
                  • Apr 2013
                  • 766
                  They didn't still get completely flush on both sides, did they?
                  • mpowerful
                    • Jul 2013
                    • 1273
                    Why dont more people use the e34 525i cylinder shaped mounts? You just grind the alignment nub off, bolt, and go. They work great and cost like 10 bucks each.
                    • 328ijunkie
                      • May 2007
                      • 3961
                      very flexable.
                      • mpowerful
                        • Jul 2013
                        • 1273
                        Mine dont seem to be moving about at all.
                        • mpowerful
                          • Jul 2013
                          • 1273
                          My motor on e34 mounts. Barely any movement at all after 12000 miles and they look just fine.
                          • Sea Aych
                            • Apr 2013
                            • 766
                            https://www.youtube.com/watch?v=VI9Cq9ulkpg
                            Cool, thanks!
                            Just picked two up - will be trying them out!
