Finally bled the clutch last night and have some weird clutch pedal behavior. Basically when pressing the clutch pedal, its like "easy" to press the pedal the first inch or so and then becomes "harder" at a certain point and feels like normal clutch pedal operation.
Almost as if for the first inch it is not applying pressure to the pressure plate in order to release the clutch. But after an inch of travel, it becomes "taught" and operates as normal.
Or am I just describing symptoms of needing to bleed the clutch further?
Original setup: m20b25 g260 with stock clutch/flywheel
New setup: s52 g260 with JBR 11lb flywheel and s50 clutch and pressure plate and IE stainless clutch line (using s50 clutch and pressure plate because the flywheel was originally for s50)
I can measure the total height of the flywheel, clutch and pressure plate from the m20 to compare to the total height of the new setup... however the new stuff is already installed.....
Any ideas?
Any ideas?
