I'm getting the fuel pump relay code and not sure exactly what to rule out at the moment.
The car has an M50Tu but started out 318i. Car runs and drives "normally" Currently throwing out 3 codes which may all be related. 1. Evap (no purge valve, its in the mail) 2. Fuel Pump Relay 3. Vanos (I'm wondering if it's affected by the other two so it's last on my list)
So i have a few questions.
1. Is the e30 318i fuel pump enough to supply fuel for the bigger motor? Anyone else have that?
2. I pulled the Fuel Pump Relay out and applied direct current to it and it still clicks. Can it still be bad? How do I check further than that?
3. Is continuous running of a fuel pump a sign that it is going bad or is that something else?
Just to clarify. The car starts and drives (not a no start issue). If I pull the relay out there is no power to the fuel pump.
Thanks in advance.
Thanks in advance.
