I got as close as I could... '84 318 s50 swap wiring help plzzzz
  • brainfood
    • Jun 2013
    • 129
    So this is where I've gotten myself to so far, can anyone help out some more and let me know how close I am, what should be changed or added?
    Any help would be appreciated, I'm trying to finish up bay prep today (did a partial shave) and it would be nice to get some wiring done soon too.
    WNY e30 Group on FB, feel free to join if you're from the area!
    @mriterphoto on instagram
    "Being airborne in an e30 is one of the worst ideas that I've done more than a couple dozen times"
    me-"I've got one of those rare 7cyl low-comp S62's"
    MattAvino- "Those aren't rare"
  • 2mAn
    Señior Mod
    • 21088
    C101 ____________<-> X20
    #1 Blue_________ <-> #25 Blue________ = Alternator
    #4 Violet/ Brown__<-> #12 Violet/ Brown = Coolant Temp
    #7 Green/ Violet__<-> #13 Green/ Violet_ = Fuel Pump
    #8 Black/ Yellow__<-> #18 Black/ Yellow = Starter
    #10 Green________<-> #21 Green ______ = Power Supply w/ Ignition ON
    #16 Brown/ Green_<-> #23 Brown/ White = Oil Pressure
    #17 Blue/ White___<-> #19 White/ Green = Service Indicator Light
    C104____________ <-> X20
    Black____________<-> #20 Black ______ = Tach
    Yellow ___________<-> #24 White/ Black = Fuel Consumption
    Im not 100% on the C104 colors though. but that literally is what my car is running on right now. 84 318 car with a OBD1 E34 Harness, so the X20 might not be 100% similar. Also, you are pretty close! Keep it up. The 84 318 is an amazing car with a 24v, especially if yours has manual windows and locks like mine does. My car weighs 2450, but I have an aluminum block also, so you'll probably be right around 2500
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • brainfood
      • Jun 2013
      • 129
      Awesome, thank you so much! And I have electric windows and locks, but I was considering converting at least the windows at some point. I'm also pretty stripped out, should be fun! What trans/diff combo are you running?
      • 2mAn
        Señior Mod
        • 21088
        I didnt bother stripping it out. Its my daily. Im using the G260 and 3.73 LSD rear end. I love it. I get 25-28mpg on the freeway depending on how much pedal Im using.
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        • Holland
          • Nov 2008
          • 7212
          Subscribed. I'm curious as I will be doing the same in coming months.
          Originally posted by DEV0 E30
