Bypassing power distribution block
  • 1990E30
    • Nov 2014
    • 8
    May sound like a dumb question, but this has been my first custom motor swap and I wanted to make sure everything is right. My E30 has the battery under the hood. The E36 I pulled my motor and trans from had the battery in the trunk. Am I fine just to bypass the block and run a red cable from the starter to the battery with the battery connection on it, or is there an additional purpose to the block aside from a jumping point? I have access to tons of E36 parts cars and found a 318i with the battery under the hood. Was going to pull the cable from that to run on my swap.
  • mpowerful
    • Jul 2013
    • 1273
    There are atleast two other small power wires that feed the harness that need to be hooked up. I solved this by using an aftermarket power distribution block screwed down to the battery tray. I run main battery cable to it an then everything gets power from there. Makes nice clean install. Mine is a vert too and i kept the battery under the hood.
