What's up R3V! Calling out the gurus of this swap section for a quick question that I'm receiving mixed reviews about...
Long story short: I pulled a ZF310 from a 91 E34 525i (with the "225" engraved on trans + "ATF Fluid" ORANGE label). Note: 91-92 were the only years the manual trans used was the ZF310, and the only years they required ATF.
Initially, I assumed this was the same exact trans used in the 95 E36 M3s.
http://www.r3vlimited.com/board/showthread.php?t=307602 -- This thread is saying these are the same.
http://www.bimmerforums.com/forum/showthread.php?1236565-95-M3-ZF-trans-vs-96-99-M3-ZF-Trans -- This thread is saying I need a different 'shifter rod'?
My Question is: Is this the same trans used in the US 95 E36 M3s? If so, the length should be the exact same as the ZF320 used in the later 96+ M3s? AND, is there anything else that is different; ie trans mounts, shift carrier, selector rod, flywheel, etc..?
BTW, I am bolting this trans to a US S50 and dropping it into an E30
Regards
- Harp
Regards
- Harp
