False RPM reading S50 swap
  • vitiokas95
    • Dec 2013
    • 482
    Need an advice on where to start looking to fix false rpm reading. Per my tach my redline is somewhere around 6200 rpm, which should be around 7200-7400 area. I have SSSquid chip installed.
    1990 e30 325is S50 swap (NASA GTS2 race car)
    1990 e30 325is
    1988 e30 M3 S50 euro swap
  • vitiokas95
    • Dec 2013
    • 482
    Fixed faulty to false sorry.
    1990 e30 325is
    • vitiokas95
      • Dec 2013
      • 482
      Anyone?
      1990 e30 325is
      • 36brua
        • 689
        put stk chip back in and compare ?
        My CA legal M60 swap
        The happening in our garage
        • vitiokas95
          • Dec 2013
          • 482
          don't have one, engine came with Turner software, I replaced it with Sssquid
          1990 e30 325is
          • jt223539
            • Apr 2011
            • 139
            What car did you do the swap in?
            • Gregs///M
              • Mar 2012
              • 2459
              Make sure you have the 325i coding plug in your cluster. Part number should end in 468.
              Owner - Bavarian Restoration
              BMW and European Electronics Repair and Restoration
              www.BavRest.com
              My Feedback Thread
              Our Facebook!
              Follow our Instagram!
              • M3PO
                • May 2012
                • 537
                Low redline can be a VSS signal issue.
                • vitiokas95
                  • Dec 2013
                  • 482
                  S50 swapped into '90 325is
                  1990 e30 325is
                  • vitiokas95
                    • Dec 2013
                    • 482
                    I will remove cluster tonight to check it out.
                    1990 e30 325is
                    • jt223539
                      • Apr 2011
                      • 139
                      Is the cluster came from a 318, it would have the 7000rpm tach, but read wrong. It was my problem when I did my swap.
                      • nrubenstein
                        • 3148
                        This.
                        2002 BMW M3 Alpinweiß/Black
                        1999 323i GTS2 Alpinweiß
                        1995 M3 Dakargelb/Black
                        - S50B32/S6S420G/3.91
                        1990 325is Brilliantrot/Tan
                        1989 M3 Alpinweiß/Black
                        • Wh33lhop
                          • 11705
                          And 6200 is usually where it cuts out for no VSS.
                          paint sucks
                          • vitiokas95
                            • Dec 2013
                            • 482
                            OK, how can I fix it?
                            1990 e30 325is
                            • Wh33lhop
                              • 11705
                              Make sure the DME is getting the VSS (vehicle speed signal). Should just be a wire you connect to the c101.
                              paint sucks
