S52 Exhaust Manifold Flange.
  • SoloMid
    • Jan 2014
    • 11
    Hi got a S52 in a 1990 325is running but she needs an exhaust now.
    I have a friend who can do the welding but I need to gather up some parts...I need flanges to weld on the downpipe to mate up to the existing ones on the S52 stock manifolds.
    Does anyone know what size they exactly are and where to get some? I tried measuring in the car and it seemed to be 1.75 ID and 2 7/8 from bolt to bolt. Can't find anything online either...
    Any help appreciated.
    Cheers.
  • Sh3rpak!ng
    • Jan 2014
    • 2667
    I went to a junkyard and cut flanges of a junked e36 for my exhaust
    maybe someone is selling them on ebay
    Shadetree30
    • marek|steezkal
      • Dec 2014
      • 91
      I couldn't find any online either. Even at ColumbiaRiverMandrel. I just made my own out of a steel plate. I can try to find my template w/measurements when I get home.
      '90 325is Schwarz
      5 lug'd 24V Turbo on VEMS
      • SoloMid
        • Jan 2014
        • 11
        That would be much appreciated.
        • marek|steezkal
          • Dec 2014
          • 91
          Be careful if you are printing this and using as a stencil (if you end up making your own flanges). You might need to resize the photo so that the dimensions are true when printed.
          Hope this is of some help.
          OBDII (late model 328 and M3) collector flanges
          [IMG][/IMG]
          '90 325is Schwarz
          • CENTURION
            • May 2015
            • 372
            I'm getting close to setting up my exhaust as well. s52 with stock headers.
            are you going to go with dual piping and xpipe?
            what's your setup gonna be like?
            thanks
            • marek|steezkal
              • Dec 2014
              • 91
              Mine is a Y-Pipe right after the headers and I have 2.5" mild steel piping all the way with a Magnaflow cat, Borla Muffler, and a cheap ebay rear muffler for now. This is on an M50 which I will be going turbo next spring so I did single piping for easier welding for the temporary exhaust.
              If I were S52 naturally aspirated, I would go dual stainless piping with an x-pipe up front. You could just find a used 96-99 M3 mid pipe and have it modified to correctly fit the E30. From what I've seen, the stock M3 exhaust was pretty well tuned from factory.
              '90 325is Schwarz
              • MaxBell
                • 1391
                I cut off the flange and welded a V-band on. Never will I have to deal with the stuck bolts and frustration of rust.
                REMEMBER: Be safe and have fun is Rule Number 1.
                The Epic Unbuild of Clint Eastwood
                • CENTURION
                  • May 2015
                  • 372
                  your advice on NA S52 is exactly the idea I wanted to go with. 2.5 all the way I suppose. just gotta find the cats and resonator from 96-99 m3.
                  thanks.
