Firewall wire harness grommet, what are you using on your 24v swap?
  • dunebuggyjay
    • Nov 2011
    • 257
    Hi Guys, what are you using for a grommet on the firewall where the wiring harness goes threw? Did you re-use the e30 one? Any tips on removal an installation? Im not sure it will fit over the ecu connector to come off, and back on. Has anyone waffleswaffleswaffles this? I suppose I could cut a slit in the stock grommet so its bigger. But worried about water getting in.
    Any suggestions?
    Thanks,
    Jay
  • jt223539
    • Apr 2011
    • 139
    I have never had any water get in through that hole. I just cut some rubber tubing in half, and covered the edge of the firewall hole.
    • mpowerful
      • Jul 2013
      • 1273
      I cut an e30 one down the center and put it around the e36 harness. Works perfect. No water.
      • efficient
        • Feb 2012
        • 3312
        I don't run the grommet and no water
        • mpowerful
          • Jul 2013
          • 1273
          Its rains 4 inches an hour in new orleans on a refular basis this time a year.
          • GDA
            • 446
            New grommets are supple, keep the dust and bugs out and add just a touch of noise suppression.
            If you are working on the harness just install new ones. I did it on my swap and installed a new elephant trunk as well.
            • M3PO
              • May 2012
              • 537
              I used the squarish one that came on the E36 harness. I squared up the hole in the firewall to make it fit and painted the cut edges.
              • 328ijunkie
                • May 2007
                • 3961
                E30 one works perfect if you can chop it off your original harness.
                Check Us out on Facebook
                Full Product Line Tuning
                • dunebuggyjay
                  • Nov 2011
                  • 257
                  Yup that what i plan on doing.
                  Thanks guys!
                  Jay
                  • Northern
                    I like cupcakes & sh!tboxes
                    • 5251
                    +1 to E30 one cut off an old harness.
                    Originally posted by priapism
                    Originally posted by shameson
                    • sweet3
                      • Oct 2012
                      • 752
                      +1 to E30 grommet. I also have the plastic firewall harness covers and that adds some extra coverage
                      PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
