M52 swap
    M52 swap
    I can get an engine out of a 528i. Is that gonna be the same as a 328i? And what Ecu can I use?
    '87 325ic
    '91 318is (first car) sold
    '99 m3 (sold)
    '84 porsche 944 (sold)
    '01 subaru legacy wagon
    Same engine, though I believe there are some subtle differences in the engine harnesses. For OBDII you'll need an MS41.1 ECU.
    Originally posted by kronus
      Yep, the harness is different. The 5-series harnesses are shorter I believe which makes placement of the DME a little more challenging. The upside is that the 5-series harness is wired for the oil level sensor (the 3-series harness isn't).
        E39 harness isnt feasable to use. Has sepearate diag port wired through body harness...
        Check Us out on Facebook
        Full Product Line Tuning
