PNP Adapter Harness Wiring for M50, M52, S50, & S52 (And MORE!)
  • sweet3
    • Oct 2012
    • 752
    LIFETIME warranty on workmanship with proof of purchase.
    Your One-Stop shop for all premium wiring needs. If you don’t see a kit for your setup, send us a message. We have several add-on options which are not listed.
    We offer an A/C solution for the M52TU, M54, S54, M62, M62TU, and S62 swaps.
    These can be prewired into the harness adapter, or added on separately if you already have a harness adapter.
    https://www.redline-motorsport.com
    You can reach us at: sales@redline-motorsport.com
    ALL harnesses use high temperature automotive TXL wiring.
    No-Longer-Available (Discontinued) connectors such as (E12/E21/E30 Square C101, C104, Z3M S54) will be high quality reproductions to allow for a simple Plug-and-Play solution. If we have a Genuine used connector available, we will use those before the reproduction style. No extra rewiring will be required.
    M50, M52(single vanos), S50 (US and Euro), S52
    (For E36, E34, Z3 engine harnesses)
    $195
    *If you plan to use the E39 obd2 harness for the M52(single vanos), we have a separate listing for that style (see website for details).
    These include the following options:
    . • OBD1 (M50/S50 harness) or OBD2 (M52/S52 harness)
    . • Cluster coolant temperature Wiring
    . • C104 Wiring (82-87 models)
    Options:
    . • Oil level sensor wiring
    . • A/C input wiring
    . • ABS power wire if you have a 90+ model
    . • Oil temperature wiring (e30 M3 upon request)
    . • OBD2 diagnostic ports are available as well for the M52 and S52 engines (upon request)
    M52TU, M54, S54, M62TU and S62
    *Required ECUs for these harnesses are the following: MS42, MS43, MS45, MSS54 or MSS54HP, ME7.2, MSS52**
    We can make these for the E46, E39, or Z3M harness.
    $375
    These include the following:
    . • Cluster coolant temperature wiring
    . • Fuel pump relay wiring
    . • Sport button for the S54/S62
    . • Electronic pedal connector for the M54, S54, M62TU, and S62
    Options:
    . • A/C module ($220) - Made by us at Redline-Motorsport
    . • ABS power
    EWS must be deleted from your DME.
    ECU Tuning
    EWS deletes available for the following:
    . M52TU (MS42)
    . M54 (MS43 B22, B25, or B30)
    . S54 (MSS54 or MSS54HP)
    . S62 (MSS52)
    You will just need to send us your ECU to be modified.
    M60, M62 obd1 converted
    **Intended to be used with the E34 or E32 engine harness with the round X20 connector.
    $195
    M60 (E38 version without round X20)
    $285
    M62 (Post 97)
    (Intended to be used with the ME5.2.1 ecu, part# 1437284) (5 ECU plugs)
    $375
    Options:
    . • ABS power wire if you have a e30 1990 and newer models
    . • A/C module ($200) - Made by us at Redline-Motorsport
    These DO NOT include A/C wiring.
    M62 (Pre 97)
    (Intended to be used with the 474 ECU, Bosch ME5.2) (1 single ECU plug)
    $285
    Options:
    N52 and N54 (Includes CAN-Bus module)
    *Required ECUs for these harnesses are the following: MSV70, MSV80, MSD80/MSD81
    We can make these for the E60/E61 and E90/E91/E92/E93 harnesses.
    $500
    . • Fuel pump relay and wiring
    . • Electronic pedal wiring
    . • CAN-Bus emulator module
    Best paired with a matching set of the following:
    - DME
    - CAS Module with ribbon
    - Key and key reader
    However, if you decide to get an EWS/CAS delete, a matching set will not be required. Several companies offer this service now. Message for referrals.
    Benchflash harness for MS42, MS43, MS45, ME7.2, MSS54/HP, and MSS52
    $100.00
    We do offer an ECU benchflash harness to reflash your DME outside of the car.
    It will come with instructions and links for the necessary software.
    For pictures, please refer to the website. We are continuously adding to our website.
    We can make conversion kits for the E9, 1602, 2002, E12, E21, E24, E28, E30, E34, E36, Z3, E39, and E46 chassis.
    PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
  • CENTURION
    • May 2015
    • 372
    I think I just bought one from you recently. it's on my build thread. letthebasskick04?????
    • NotJesus
      • Mar 2015
      • 169
      Do only the 'e' models require that you run the tach, mpg, and speed signal through the harness?
      • schmidty
        • 1253
        I'll definitely jump on this when I'm a little closer to getting my m52 installed.
        Do I need to send you the harnesses or do you use your own?
        • sweet3
          • Oct 2012
          • 752
          No, there are actually some 87 "i" models that use them as well. An easy way to tell is if you see a 3 pin connector (c104) in your glovebox area. Pin 1 should be black, pin 2 should be red/green, and pin 3 should be yellow/white. If you have this connector, then you will need the extra wires.
          The extra wires are included with the harness (if your model requires it)
          • sweet3
            • Oct 2012
            • 752
            Excellent, just send me a message whenever you are ready.
            If you want your harness repinned, then you would need to send your own harness.
            If you would just like the adapter harness (like the pictures above), then you wouldnt need to send me your harness.
            • ba114
              • Sep 2015
              • 364
              Do you do harnesses for:
              '89 318i (M40b18) adapted to M52 with M50 intake?
              Shipping to Australia required.
              Thanks
              RHD OBD2 M50b25 turbo build thread:
              http://www.r3vlimited.com/board/showthread.php?t=384800
              • sweet3
                • Oct 2012
                • 752
                Thanks
                Yes we can make them for the e30s that had the m40 originally.
                • sweet3
                  • Oct 2012
                  • 752
                  Bump
                  • calypsorote30
                    • Oct 2013
                    • 70
                    You make a harness adapter for a 1990 bmw 325i m52 swap obd2
                    • sweet3
                      • Oct 2012
                      • 752
                      PMed
                      • djd834
                        • Oct 2015
                        • 4
                        Are the 1991 318is harness adapters still for sale. Was going to repin but trying to get it done quick. For a m50nv
                        • sweet3
                          • Oct 2012
                          • 752
                          Hi, yes they're still for sale. I'll send you a PM
                          • jmitch1769
                            • Oct 2015
                            • 14
                            Hey, do you have an adapter for '85 318i for s50 swap?
                            • George E30
                              • Oct 2015
                              • 79
                              Hey Im doing a s52 swap in my e30, I need a harness how can I purchase one
                              Sent from my SAMSUNG-SM-G890A using Tapatalk
