PNP Adapter Harness Wiring for M50, M52, S50, & S52 (And MORE!)
    LIFETIME warranty on workmanship with proof of purchase.
    Want to get your swap finished quicker? These adapters will save you a lot of headaches and hassle.
    We now offer an A/C solution for the M52TU, M54, S54, M62, M62TU, and S62 swaps.
    These can be prewired into the harness adapter, or added on separately if you already have a harness adapter.
    Message or Email us for more information.
    https://www.redline-motorsport.com
    You can reach us at: sales@redline-motorsport.com
    All additional options are included in the prices. All standard relays and fuses are included (With an exception of the S54/S62 EKP Module)
    NLA connectors such as (E12/E21/E30 Square C101, C104, Z3M S54) will be high quality reproductions to allow for a simple Plug-and-Play solution. If we have a used connector available, we will use those before the reproduction style. No extra rewiring will be required.
    M50, M52(single vanos), S50 (US and Euro), S52
    (For E36, E34, Z3 engine harnesses)
    $180
    *If you plan to use the E39 obd2 harness for the M52(single vanos), we have a separate listing for that style (see website for details).
    These include the following options:
    . • OBD1 (M50/S50 harness) or OBD2 (M52/S52 harness)
    . • Cluster coolant temperature Wiring
    . • C104 Wiring (82-87 models)
    Options:
    . • Oil level sensor wiring
    . • A/C input wiring
    . • ABS power wire if you have a 90+ model
    . • Oil temperature wiring if you have an e30 M3 or the e30 M3 cluster
    . • OBD2 diagnostic ports are available as well for the M52 and S52 engines (Special request)
    M52TU, M54, S54, M62TU and S62
    *Required ECUs for these harnesses are the following: MS42, MS43, MSS54 or MSS54HP, ME7.2, MSS52**
    We can make these for the E46, E39, or Z3M harness.
    $365
    These include the following:
    . • Cluster coolant temperature wiring
    . • Fuel pump relay wiring (The S54/S62 use PN# 61357892976. If you rather have a standard relay, please let us know so that we can make that change)
    . • Sport button for the S54 and S62
    . • Electronic pedal connector for the M54, S54, M62TU, and S62
    Options:
    . • A/C module ($200) - Made by us at Redline-Motorsport
    . • Secondary Air Pump relay and wiring
    . • Oil level sensor wiring (Except S54, M62TU, or S62) *Unless you request it*
    . • ABS power wire if you have a e30 1990 and newer models
    EWS must be deleted from your DME.
    ECU Tuning
    $75 (EWS Delete is FREE with a harness purchase).
    EWS deletes available for the following:
    . M52TU (MS42)
    . M54 (MS43 B22, B25, or B30)
    . S54 (MSS54 or MSS54HP)
    . S62 (MSS52)
    Additional options:
    . Secondary Air Pump Delete
    . Rear o2 Delete
    . Cat Delete
    . Top Speed Delete
    . VSS removal
    . Rev limit adjustment
    . Sport Mode Memory
    You will just need to send us your ECU to be modified.
    M60, M62 obd1 converted
    **Intended to be used with the E34 engine harness with the round X20 connector.
    $180
    M60 (E38 version without round X20)
    $275
    M62 (Post 97)
    (Intended to be used with the ME5.2.1 ecu, part# 1437284) (5 ECU plugs)
    $365
    Options:
    These DO NOT include A/C wiring.
    M62 (Pre 97)
    (Intended to be used with the 474 ECU, Bosch ME5.2) (1 single ECU plug)
    $275
    Options:
    N52 and N54 (Includes CAN-Bus module)
    *Required ECUs for these harnesses are the following: MSV70, MSV80, MSD80/MSD81
    We can make these for the E60/E61 and E90/E91/E92/E93 harnesses.
    $500
    . • Fuel pump relay and wiring
    . • Electronic pedal wiring
    . • CAN-Bus emulator module
    Best paired with a matching set of the following:
    - DME
    - CAS Module with ribbon
    - Key and key reader
    However, if you decide to get an EWS/CAS delete, a matching set will not be required. Several companies offer this service now. Message for referrals.
    Benchflash harness for MS42, MS43, MS45, ME7.2, MSS54/HP, and MSS52
    $65.00
    We do offer an ECU benchflash harness to reflash your DME outside of the car.
    It will come with instructions and links for the necessary software.
    It is intended to be used with any 12v power supply. It is suggested to use one that only reaches 5 amps maximum. Otherwise, I suggest to add a fuse to the (+) terminal on the benchflash harness.
    You will just need to get an INPA K+DCAN cable and/or Galletto 1260 cable. These options are explained in the included instructions.
    Radiator/Auxiliary fan wiring is now available. This wiring is intended for the E30, E36, or E46 original auxiliary fans.
    The E30 and E36 fans will need to be used with the 88/80c radiator temperature sensor, part# 61318361787.
    If you have another option in mind, contact us to see if we can provide a harness for your setup.
    For pictures, please refer to the website. We are continuously adding to our website.
    We can make conversion kits for the E9, 1602, 2002, E12, E21, E24, E28, E30, E34, E36, Z3, E39, and E46 chassis.
    PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
    I think I just bought one from you recently. it's on my build thread. letthebasskick04?????
      Do only the 'e' models require that you run the tach, mpg, and speed signal through the harness?
        I'll definitely jump on this when I'm a little closer to getting my m52 installed.
        Do I need to send you the harnesses or do you use your own?
          No, there are actually some 87 "i" models that use them as well. An easy way to tell is if you see a 3 pin connector (c104) in your glovebox area. Pin 1 should be black, pin 2 should be red/green, and pin 3 should be yellow/white. If you have this connector, then you will need the extra wires.
          The extra wires are included with the harness (if your model requires it)
            Excellent, just send me a message whenever you are ready.
            If you want your harness repinned, then you would need to send your own harness.
            If you would just like the adapter harness (like the pictures above), then you wouldnt need to send me your harness.
              Do you do harnesses for:
              '89 318i (M40b18) adapted to M52 with M50 intake?
              Shipping to Australia required.
              Thanks
              RHD OBD2 M50b25 turbo build thread:
              http://www.r3vlimited.com/board/showthread.php?t=384800
                Thanks
                Yes we can make them for the e30s that had the m40 originally.
                  Bump
                    You make a harness adapter for a 1990 bmw 325i m52 swap obd2
                      PMed
                        Are the 1991 318is harness adapters still for sale. Was going to repin but trying to get it done quick. For a m50nv
                          Hi, yes they're still for sale. I'll send you a PM
                            Hey, do you have an adapter for '85 318i for s50 swap?
                              Hey Im doing a s52 swap in my e30, I need a harness how can I purchase one
                              Sent from my SAMSUNG-SM-G890A using Tapatalk
